I have a problem with a solar charger based on bq24650. The output voltage is designed to charge lead acid or lion batteries (see the switch on schematic).
For testing purposes the circuit is powered from power supply. Without load the circuit behaves as expected and on the output is also expected voltage. But if the load is connected, the output voltage is osciallating, see the picture bellow. What could be problem?
Thak you.
