Other Parts Discussed in Thread: BQ2000, BQ2000T, BQ24765
We are using NiMH battery and we will need 50-64mA charging current
We have several question about BQ24780S:
1)BQ24780S didn’t support NiMH before March 2017, did it?(I haven’t found it in parametric search 3 weeks ago)
Now on the BQ24780S web page lists NiMH.
But there are no confirmation in datasheet.
So does it support NiMH chemistry?
2)We will need 50-64mA charging current
On the page 32 of datasheet described that charge current controls by register from 128mA to 4A with 10mOhm resistor(table below).
Can we just write logic 1 to 6bit to make charge current 64mA?
Or do we need to write logic 1 to 7bit to make charge current 128mA and use 20mOhm resistor to decrease charge current to 64mA?
3)There are NO any graphs for constant current charging mode/constant voltage charging mode.
Can you provide this graphs to us. Datasheet don’t provide it.
Also the description of paragraph 7.3.3 is not complete.
4)Due to the question 2), if we will use only 7bit of charging current and 20mOhm resistor(to make it 64mA) what values of the resistors should be for the R10/R11?(For the correct working ILIM)
Ilya.
