Other Parts Discussed in Thread: BQ24600
- The 18(REGN),20(PH),21(HIDRV) pins are getting shorted with 17(GND) pin,sometimes BTST pin also get shorted with GND.
- The LODRV mosfet (SIS412DN) terminal also damaged
Hi Stalin,
There are something need your help,
Ann Lien
SCHEMATIC_BATTERY CHARGING CIRCUIT.pdfSchematic and other waveforms with and without input power supply and connected battery attached here as per your reply.The HIDRV mosfet OR pin not getting damaged.And there is no possibility to get waveform after dupilcating the issue as the IC pins shorted with the GND.
Hi Ann,
The uploaded waveform name is mentioned as name of each image. Please save the image to know the waveform pin details. And the circuit battery terminal short happens after couple of cycle charging only. It is not happening when we plunging battery first time to the battery terminal. We are looking forward to your response
Thank you
Stalin joseph
Hi Stalin,
Thanks for your data collects.
For your schematic,you need to setup ACP/ACN, ISET2, ACSET to let charger work normally. Has this design ever worked normally when this issue didn't come? If you don't want to use input current limit and too much output component, you can use bq24600 to replace bq24617.
How about your system connection? It is connected to battery or Vin? It determines battery's inrush current direction.
How often this issue occurred? Every time you plugged the battery or it is random?
The damaged is related to bootstrap circuit. Is bootstrap diode good or damaged?
Ann Lien
Hi Ann,
Is there any solution, as the local TI support members are insist to stick with global forum for problem resolution. Please give us better way to solve the issue as we are on the stage of production of our device.
Thanks you
Stalin Joseph
Hi Stalin,
Sorry for the late reply.
We're trying to give a explanation on this case. in order to speed up the support, you can email me through ann_lien@ti.com.
Ann Lien
