We are using BQ24005 for charging two pin battery.
We have set the voltage in APG/THM pin within the specified limit.
Battery charging has no issue, but without battery, the IC indicates full charge status (STATUS1 = High, STATUS2 = Low) with adapter alone connected.
Is this status common, since we observed the same in the few boards we tested.
Thank you!
Felicita Mercy D.
