Dear TI Team.
I have a heating problem during the TEST for BQ24190.
When the PCB is made and the battery is connected directly, the temperature of the BQ24190 goes up to 65 degrees.
To check the charging current, disconnect the + terminal of the battery and connect the current meter to operate the BQ24190.
It drops to about 45 degrees. Is it possible to determine what the cause is?
Thanks.
