As stated in datasheet, we know that the ceramic capacitor has dc-bias effect, so the customer consider to use only POSCAP as output capacitor to reduce total component area.
- Then can you recommend to use only POSCAP as output capacitor? The main concern is loop stability.
- At the case only ceramic capacitor, you recommend to place minimum 6pcs of 10uF, then is the 47uF POSCAP enough with stable operation?
Satoshi / Japan Disty
