In some cases, it might be desirable to disconnected the battery (BATFET Off). We might also have product without the battery.
Can you tell us what is the behavior of SYS in those conditions? What voltage can we expect at the SYS pin when the battery is disconnected or not present? Basically can we use the device as a buck converter to convert the input voltage to a lower value.
