Other Parts Discussed in Thread: BQ40Z60, BQ40Z50-R2
The AC Present input pin (ACP pin31) stays hi when AC is removed (any work around?).
Scenario:
The battery voltage is leaking back to the ACP pin and holding it up (thereby confusing the charger chip to think it should be charging).
The ACP pin should be driven lo when the AC power is removed but this is not happening.
The battery voltage is leaking back through Q8 body diode (hi side charge FET) and Q5 thereby holding the ACP hi (not good).
This is causing the charger chip (bq40z60) to try charging the battery from the battery (??) thereby drains the battery prematurely when our circuit is OFF.
thanks,
Tom
