Texas Instruments
  • Samples Cart - Add Samples Samples & Purchase Cart
  • Contact Us
  • TI Worldwide: United States
  • my.TI Login
  • Products
  • Applications
  • Design Support
  • Sample & Buy
  • All Searches
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Gas Gauge Forum » BQ78PL114 voltage measurements callibration
  • Join
  • Sign In with my.TI Login
TI E2E™ Community
  • Home
  • Support Forums
  • Videos
  • Blogs
  • Groups
  • More ...
  • Go
  • Advanced Search
Share
Details
Rate This
  • 3 Replies
  • 2 Subscribers
  • 223 Views
  • Posted3 months ago
Options
  • Subscribe via RSS
Tags
  • "bq27510" "step by step" "DFI"
  • "BQ78pl114"
  • "cell simulator"
  • "EINT" in pack status
  • "USB TO GPIO" DONGEL
  • *.bqfs
  • *.dffs
  • *.dfi
  • *.senc
  • .chem files
  • .dfi
  • .net
  • .rom
  • .senc firmware Chemistry ID
  • 0 cell found
  • 0 cells found
  • 0100 0107 0135 UR18650FM bq20z95 bqeasy
  • 0x16
  • 0x17
  • 10-cell
  • 10mWh
  • 114
  • 114 charge pump
  • 12V
  • 12V Lead-Acid
Forum - Title
Battery Management
Battery Management
Welcome to the Battery Management Section of the TI E2E Support Community. Ask questions, share knowledge, explore ideas, and help solve problems with fellow engineers. To post a question, click on the forum tab then "New Post".
  • Get this RSS feed
  • Home
  • Forums
  • Files
  • Design Notes
New Post
This question is not answered
Piotr Bigaj
Posted by Piotr Bigaj
on Feb 7, 2012 9:26 AM
Prodigy170 points
I know that hes subject was rised in several threads, but non of them gave me full answer on my question.
I have 10s1p pack connected to BQ78PL114 and 3 pieces of BQ6PL102. I have noticed that voltage measured by BQ78PL114 have an offset of around 200mV. I have just connected BQ78PL114 repregrammed it to be S12 and modified it to work with 10s1p pack
1. What causes this offset?
2,. Can I callibrate cell voltage using BQWizzard?
3. Is there any factory calibration file to download to BQ8PL114 ? Where can I download these files from?
4. Shall I preserve callibration before firmware update in next PCB pieces?
any answer would be very helpfull
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • ThomasCosby
    Posted by ThomasCosby
    on Feb 11, 2012 10:30 AM
    Expert6180 points
    Piotr,
    There should not be an offset on the PL102 devices. The PL102 calibration information will be downloaded to the PL114 when a Relearn and Initialize command is sent to the device. The voltage measurement is calibrated at the factory and cannot be calibrated at your site.
    Tom
    Report Abuse
    • Reply
  • Piotr Bigaj
    on Feb 14, 2012 1:51 AM
    Prodigy170 points
    Tom,
    you are right - there is no voltage offset on BQ76PL102 device, but there is on every cell measured by BQ76PL114 device. How do I get rid off this offset?  Is replacing BQ78PL114 the only option? I have reprogrammed the device with 5000 firmare, but measurements are still having this 200mV error.
    You say that 114 device cannot be callibrated @ my site - but there is such option in BQWizzard software.
    BR,
    Piotr
    Report Abuse
    • Reply
  • ThomasCosby
    on Feb 14, 2012 8:13 AM
    Expert6180 points
    Piotr,
    Sorry about the confusion. You are correct that cell voltages can be recalibrated by the user on the PL114. I normally work with the PL116 and you do not have the option to calibrate voltages with it. I had not tried cell voltage calibration on the PL114, so I did so this morning. I deleted the calibration data on my EVM and the cell voltage measurements were off. I used the Calibration utility on bqWizard to calibrate the cell voltages and the reported measurements were then within 1mV of the cell voltages. Hopefully, you will be able to calibrated your devices as well. I am not sure how your calibration data got deleted.
    Tom
    Report Abuse
    • Reply
Share
ALL CONTENT AND MATERIALS ON THIS SITE ARE PROVIDED "AS IS". TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH REGARD TO THESE MATERIALS, INCLUDING BUT NOT LIMITED TO ALL IMPLIED WARRANTIES AND CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHT. TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH RESPECT TO THESE MATERIALS. NO LICENSE, EITHER EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE, IS GRANTED BY TI. USE OF THE INFORMATION ON THIS SITE MAY REQUIRE A LICENSE FROM A THIRD PARTY, OR A LICENSE FROM TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Products | Applications | Design Support | Sample & Buy RSS
TI Worldwide | About TI | Contact Us | Investor Relations | Press Center | Corporate Citizenship | Careers | Tags | my.TI Login | All Searches | Site Map
© Copyright 1995- Texas Instruments Incorporated. All rights reserved. Trademarks | Privacy Policy | Terms of Use
