• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Gas Gauge Forum » Can't reach 100% with BQ27200
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Jf Lemire
Posted by Jf Lemire
on Apr 10 2012 14:11 PM
Prodigy100 points
I tested the charger BQ24070 with the fuel gauge BQ27200 and I can't reach 100%. I installed the software for the eval board and execute a DONE command after eache charging cycle.
Sequence:
1) Discharge the battery to 3v.
2) Charge the battery at the max with the charger.
3) execute the command DONE.
4) restart at step 1).
The maximum reached with the fuel gauge is 95%.
Any suggestions?
JF
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • MikeV
    Posted by MikeV
    on Apr 10 2012 14:29 PM
    Intellectual1855 points
    Are you saying that even after sending the DONE command that the charge is not reaching 100% or is it that you are having to send the DONE command because SOC only reaches 95% on its own and requires the DONE to push to 100%?
    Report Abuse
    • Reply
  • Jf Lemire
    Posted by Jf Lemire
    on Apr 10 2012 14:45 PM
    Prodigy100 points
    After a DONE, the % is at 100%. But the next charge will not reach 100%. The max value reached is 95%.
    Report Abuse
    • Reply
  • MikeV
    Posted by MikeV
    on Apr 10 2012 14:58 PM
    Then the charge termination conditions are not being met.
    The bq27200 will adjust to 100% SOC once the charge termination is detected. The conditions that must be met to detect charge termination is for the voltage to be above the qualification voltage that is set with the QV1 and QV0 bits in EEPROM and the charge current must taper to below the current programmed in TAPER register of EEPROM. The taper current detection is going to have a dependency on the sense resistor value being used in design.
    Report Abuse
    • Reply
  • Jf Lemire
    Posted by Jf Lemire
    on Apr 10 2012 15:04 PM
    Prodigy100 points
    The 5th, 6th and 7th charge has stopped at 95%...
    Did I have to change Taper value in EE or something like that?
    After the learning sequence did I have to restart the learning sequence if the IC lost his power?
    Report Abuse
    • Reply
  • MikeV
    Posted by MikeV
    on Apr 10 2012 15:13 PM
    If you want the SOC to be forced to 100% upon charge termination then you must set TAPER register so that it is based on a current threshold that is a bit higher (considering charger and gauge tolerances) than the actual auomatic charge termination of the charger,
    If the IC loses power then all learned data is lost and capacity is initialized to 0%. The bq27200 is a pack side gauge which means that it should reside in the battery pack. The ony time it is expected to lose power is if the battery deeply discharges hence it will be at 0% capacity.
    Report Abuse
    • Reply
  • Jf Lemire
    Posted by Jf Lemire
    on Apr 10 2012 15:27 PM
    Prodigy100 points
    OK,
    Finally, did the DONE command is necessary or the IC will learn by himself the batt caracteristics?
    Report Abuse
    • Reply
  • MikeV
    Posted by MikeV
    on Apr 20 2012 11:06 AM
    The DONE command is sent at end of charge (full charge) only if the gauge can not detect charge termination on its own.
    I still want to understand why you needs to send the DONE command when the gauge should be detecting charge termination on its own. I may only understand what is going on if the you describe in detail what you do to make learning cycle. Details must include EEPROM contents, discharge current rate, charge termination conditions and order of events.
    Report Abuse
    • Reply
  • MikeV
    Posted by MikeV
    on Apr 20 2012 15:15 PM
    The battery characteristics are only learned if the battery is charged completely and it is then discharged to at least below the EDV1 voltage threshold that is set in EEPROM.
    Report Abuse
    • Reply
  • Jf Lemire
    Posted by Jf Lemire
    on Apr 20 2012 15:32 PM
    Prodigy100 points
    Here is the sequence I did
    1) I installed the battery on the fuel gauge. (at this moment, the batt level is unknown).
    2) I start the charger. (max reached = 52%)
    3) Discharge the battery to 2.93v
    4) recharge it. (at this moment the level is always 52% if I don't execute a DONE).
    Is it possible that the battery don't reach the EDV1?
    What is the EDV1 value?
    Report Abuse
    • Reply
  • MikeV
    Posted by MikeV
    on Apr 20 2012 15:52 PM
    The EDV1 threshold is one of the EEPROM values that establishes the capacity at 6.25% and when the capacity is learned with the bq27000. If it is still default value then it will be higher than 3V.
    Can you indicate the following:
    Have you ever had the EEPROM values programmed? If so what are the values?
    In step 2 why don't you send the DONE command?
    Can you describe your charger behavior? What's the charging voltage? At what current does it stop charging at full capacity?
    Report Abuse
    • Reply
  • Jf Lemire
    Posted by Jf Lemire
    on Apr 26 2012 09:26 AM
    Prodigy100 points
    Hello again,
    We keep all the EEPROM values at the default values, so we didn't write in the EEPROM.
    We used the DONE command at each charge, I forgot to mention it in the sequence.
    The average charge current is a little bit over 1000mA and begin to drop at 30% of charge and the charge stop at 52% (for the first charge, before we do the first DONE command). The taper current is set at 102mA when I read the EEPROM. So I think the charger stop to charge the battery when the average current reach the taper current value.
    Do I have to change something in the EEPROM or with the default values we are supposed to reach the 100% state of charge?
    Is there a specific sequence to get a valid learning cycle, because the Capcaity Inaccurate flag seems to be always at 1?
    Thanks  a lot!
    Report Abuse
    • Reply
  • MikeV
    Posted by MikeV
    on Apr 26 2012 21:15 PM
    The EEPROM must be programmed so that the ILMD is close to the design capacity of the battery, the TAPER is just above the taper current at which the charger stops and the EDV1 at the voltage at which expect that 6% of capacity is remaining. If none of these EEPROM registers are programmed accordingly you will not be able to have the bq27000 learn capacity accurately.
    Report Abuse
    • Reply
  • Jf Lemire
    Posted by Jf Lemire
    on Apr 27 2012 07:15 AM
    Prodigy100 points
    Ok, thank you! I'll do that. Also, do I have to change the value of QV1, QV0? I know that there are 4 Voltage values depending on the value of QV1 and QV0. (3968mV, 4016mV, 4064mV and 4112V). I don't know which one to select.
    Report Abuse
    • Reply
  • MikeV
    Posted by MikeV
    on Apr 27 2012 10:23 AM
    Select the QV combination that provides the highest voltage possible but that is still less than the minimum voltage for your charge when in constant voltage mode (typically 4.2V). When determining minimum voltage while in constant voltage charge mode consider the tolerances of your charger and the tolerances of the bq27000 voltage measurement.
    Report Abuse
    • Reply
  • Jf Lemire
    Posted by Jf Lemire
    on May 02 2012 10:51 AM
    Prodigy100 points
    I'm finally able to reach the 100% without using the DONE Command. But I noticed that when I reach the taper current I'm not a 99% and go to 100%. Sometimes I jump from 97% or 98% to 100% without reaching the 98% or 99%. I tried to drop the taper current a bit, but with the HEX values I can't get accurate values. I need like 111mA taper current, but the nearest value is 114mA. Is it a problem of QV1/QV0 or a taper current problem due to the non-accurate hex values. Is it normal to jump 2 or 3 % at a time when I reach the taper current?
    Regards.
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
