• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Gas Gauge Forum » Recalibration of bq20z65
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Dietmar Fischer
Posted by Dietmar Fischer
on Apr 20 2012 06:52 AM
Prodigy230 points
Dear All
Because the CF flag was set we try to recalibrate teh bq20z65 in our battery according your recommendation which I had found in this forum.
1. Charge battery to full
2. Let it relax for min 2 hours
3. Discharge battery to empty
4. Let it relax for about 5 hours
We logged the register of the bq20z65 after step 4 for about 90hours with the EV2300 and the evaluation software.
But the Max Error was still at 6% and the CF Flag = 1.
After we charge the battery to full again after step 4 and let it relax after end of charge we have observed that the CF flag was cleared and MaxError goes back to 1% after further 40 minutes.
Is this a normal behaviour?
How we can speed up a recalibration?
Thank you for your help
Dietmar
bq20z65R1
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chase7071949597
    Posted by Chase7071949597
    on Apr 20 2012 14:12 PM
    Expert6520 points
    The Max Error should have changed to 1% during step 4. Something must have disqualified a Qmax update in either step 3 or 4. It looks like you did get it to update eventually, though, so that's good.
    Depending on your chemistry ID, you might be able to update Qmax a little quicker. Qmax update requires 2 OCV points and at least a 37% change in capacity between those OCV readings. So, for example, you could charge to full, rest for 2 hours, discharge to 60%, and then rest for 5 hours. Qmax should update sometime during that 5 hour rest. However, Qmax updates are disqualified if one of the OCV points is taken while in the flat region of the OCV curve. So, this is why it depends on the chemistry ID. If you let me know the chem ID you are using I can give you the flat region voltage and SOC range.
    Report Abuse
    • Reply
  • Dietmar Fischer
    on Apr 23 2012 01:25 AM
    Prodigy230 points
    Thank you for your fast repsonse.
    The chemistry ID of the using cells is 247 and 309.
    For testing the recalibration method I set the cycle counter manually to 100 for producing the "MaxError" failure and to set the CF Flag.
    Maybe this has an influence of the behaviour which I had described.
    And could you please explain me when the MaxError will be increment with 0.5% and when not?
    If I've understood it correct this counter will be incremented if no relaxation time between charge and discharge is present during normal using.
    Thanks and best regards
    Dietmar
    Report Abuse
    • Reply
  • Dietmar Fischer
    on Apr 23 2012 01:31 AM
    Prodigy230 points
    Thank you for your fast response
    The chemistry ID of our cells is 247 and 309.
    To produce the "MaX Error" failure and to set the CF-Flag I've set the cycle counter manually to 100.
    Maybe this has an influence of the behaviour which I've described.
    And could you please explain me when the MaxError will be incremented with 0.5% after a cycle and when not?
    If I've understood it correct this incrementation can be prevent if a relaxation time after charge and discharge is present under normal using.
    Dietmar
    Report Abuse
    • Reply
  • Dietmar Fischer
    on Apr 23 2012 01:44 AM
    Prodigy230 points
    Dietmar
    Report Abuse
    • Reply
  • Chase7071949597
    on Apr 23 2012 10:04 AM
    Expert6520 points
    The Qmax disqualification region for ID 247 is 3589mV to 3641mV, which is about 30% to 47% SOC. For ID 309 it is 3736mV to 3799mV, which is about 20% to 42%. This should allow you to get a Qmax update by following the shortened procedure I gave you earlier.
    Max Error will increment by 1% for every 20 cycles it goes without a Qmax update.
    Report Abuse
    • Reply
  • Dietmar Fischer
    on Oct 29 2012 09:34 AM
    Prodigy230 points
    Hello
    I've some further questions regarding Qmax update procedure.
    1. Is it possible to become two OCV measurement points if we charge the battery from SOC=20% to SOC=60% and after relaxation time from SCOC=60% to SCOC=100%?
    2. Is the 37% change of charge required between two OCV measurements in both directions?
    For example:
    - Discharge from 100% to 60%
    - Wait
    - Charge from 60% to 100% or is it possible to charge only to 80%?
    - Wait
    3. Could I detect a proper OCV reading on the VOK-flag to reduce calibration time?
    Thanks a lot for your help
    Dietmar
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
