• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Gas Gauge Forum » using MSP430f5529 code with bq76pl536
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
ashwini chaudhari
Posted by ashwini chaudhari
on Apr 20 2012 07:32 AM
Prodigy115 points
hello,
I am working on texas  instrument's bq76pl536  evaluation board for battery management system. I received a code from texas i.e. slaa478 sample code, which i am using for my application to monitor batteries. I can get individual cell voltages of each battery connected. But i have following difficulties:
1.  How can i get  temperature values of each battery connected.
2. How can i get the information from board about how many devices/batteries attached to it.(without using predefined macros e.g. # Define).
3. How can i attach batteries with different cells to a single board. (e.g. if i can connect 3 batteries at a time. 1 with 3cells,2nd with 4 cells and 3rd with 5 cells).
Thank you,
Ashwini.
bq76PL536
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Roger Hwang
    Posted by Roger Hwang
    on Apr 30 2012 10:06 AM
    Intellectual2260 points
    1. PL536 EVM   has two temp sensor.
    2. Board doesn't give you how many device/cells attached. It has to be done by SW.
    3. See figure 4 in the bq76pl536A datasheet. It had details how to connect 3 to 6 cells.
    Report Abuse
    • Reply
  • ashwini chaudhari
    on May 14 2012 06:32 AM
    Prodigy115 points
    -> The 3 ICS on the BQ76pl536 EVM have 6 temp sensors in total. I can see correct readings of the temp of IC on the Texas BQ76pl536 Evaluation software(BQ Wizard). but while using MSP430 as Host the 2nd IC shows 0 Temp where as the other two IC's shows proper values.
    -> The current Sample code specifies same number of cells for all the BQ IC's attached. I want to have different no of cells for each IC ranging from 3-6 cells. Is it possible to attach similar configuration.
    bq76PL536
    Report Abuse
    • Reply
  • Roger Hwang
    on May 14 2012 09:25 AM
    If you go to datasheet, you will see detail of how to sets number of cells. Yes, you can see your config to anyway you want.
    Are you referring to middle IC?
    Read the registers 0x0f to 0x12 of 2nd IC.
    Does it have right value in the registers?
    Report Abuse
    • Reply
  • ashwini chaudhari
    on May 15 2012 09:40 AM
    Prodigy115 points
    registers 0x0f to 0x12 shows 0xff value............
    bq76PL536
    Report Abuse
    • Reply
  • ashwini chaudhari
    on May 15 2012 09:48 AM
    Prodigy115 points
    I am using slaa478 code from texas  for battery monitoring using msp430F5529 ....
    I  want to change over voltage and under voltage setting  value in run time  that are already defined in program as a macro ........
    is it possible???
    bq76PL536
    Report Abuse
    • Reply
  • Roger Hwang
    on May 15 2012 15:05 PM
    I think you have to change the Macro.
    Report Abuse
    • Reply
  • ashwini chaudhari
    on May 15 2012 23:36 PM
    Prodigy115 points
    thanks.................
    but It again a fixed value........at a run time how it is possible?
    bq76PL536
    Report Abuse
    • Reply
  • Roger Hwang
    on May 16 2012 10:44 AM
    you can't do that on RUN time. You need to program into the PL536.
    There is setting for COV in the code. YOu need to change it. It will then program to PL536.
    Report Abuse
    • Reply
  • ashwini chaudhari
    on May 17 2012 06:07 AM
    Prodigy115 points
    THANKS...................
     I am also using bq76pl536 evaluation GUI from texas with AARDVARK (I2C/SPI  TOTAL PHASE).....in that we can change over voltage and under voltage on run time..............
    Same thing i am trying  with msp430F5529..........but it shows error...
      I am searching for solution.........
    bq76PL536
    Report Abuse
    • Reply
  • Roger Hwang
    on May 17 2012 09:06 AM
    Ashwini,
    Let me ask you one basic question. What do you mean by run time change?
    What are you trying to do?
    Report Abuse
    • Reply
  • Nishant Kalbhor
    Posted by Nishant Kalbhor
    on May 18 2012 01:25 AM
    Prodigy10 points
    Hello Roger,
    The Evolution module when used with the AAdravark to test the evolution board works properly with the OV and OV values specified on the GUI. Where as when the sample code is use the changes in the OV and UV values work properly with balancing procedure where as the ALERT and FA ULT registers still depend on the Macro values( values of UV and OV recovery and threshold ). We want a simple working of the BMS IC where we could change the OV and UV values without re programming IC similar to the EVM GUI .
    Is there a way with which we change the threshold and recovery values of UV and OV when the program is already burned on to the IC. In this case we dont have to re program to just change the values.
    -Nishant
    Report Abuse
    • Reply
  • ashwini chaudhari
    on May 18 2012 02:17 AM
    Prodigy115 points
    Texas Instruments - bq76pl536 evaluation GUI  with AARDVARK  :
    CFG_COV for over voltage and  CFG_COV for under voltage settings.......
    We can change  these values and according to these settings it shows COV_FAULT ,CUV_FAULT , ALERT , FAULT register values....
    MSP430F5529 (SLAA478 code) :
    dCOV_THRESHOLD for over voltage and  dCUV_THRESHOLD for under  voltage settings,.......
    #define dCOV_THRESHOLD    3700
    #define dCUV_THRESHOLD    2000
    is there any way to change these macro values(settings ) without re-programming IC?
    bq76PL536
    Report Abuse
    • Reply
  • Roger Hwang
    on May 18 2012 10:59 AM
    YOu can do whatever you want.
    1. You can disable OV and UV from PL536.
    2. You can monitor the voltage and compare to your OV and UV.
    That is only way. Basically, you are trying disable PL536 2nd level protection.
    This is one way to do it.
    Report Abuse
    • Reply
  • Roger Hwang
    on May 18 2012 11:05 AM
    I sent you my phone number. Call that number. let's talk.
    Report Abuse
    • Reply
  • ashwini chaudhari
    on Aug 28 2012 04:18 AM
    Prodigy115 points
    hello,
    I am using bq76pl536 EVM with AARDVARK I2C/SPI interface. It is working properly for 3 batteries.
    Now I want to attached 6 batteries with 2 EVMs..for  that i did registers settings which converts one EVM as a Host and other is Slave. But  AARDVARK gives Communication error.
    Thank you..
    Ashwini
    bq76PL536
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
