• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Gas Gauge Forum » ev2300 windows 7 (32bit) installation problem
Share
Battery Management
  • Forums
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
arp1
Posted by arp1
on May 07 2012 04:54 AM
Prodigy20 points
i have installed USB Drivers for Windows XP and Windows 7 (Rev. A) (28 Apr 2011) in windows7 32bit as administrator (before connecting ev2300 box).
then i connected the ev2300 box: device installation unsuccessful.
i tried manually updating the driver: path to c:\windows\TI, but still not recognized (could not be found)
i also have the same problem in windows xp 32bit (sp3)
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • dMax
    Posted by dMax
    on May 09 2012 16:36 PM
    Expert7350 points
    Try installing the 64-bit drivers for EV2300.  They will also work for 32-bit systems and are newer.  Let us know if that works better.
    Report Abuse
    • Reply
  • JAG
    Posted by JAG
    on Jan 08 2013 14:34 PM
    Prodigy60 points
    Problem:
    Unable to communicate with TI EV2300.
    I have exchanged the EV2300 box with other engineers in the company. The EV2300 box is OK.
    I have installed the 32 and lately the 64 bit driver.
    My Op Sys: Windows 7 - 32 bit
    I have installed the following softwares:
    EV2300 Software - sluc017; EV2300 Driver - slec003a; EV2300 software bq20z80 - sluc107; EV2300a Device Driver Installer Multilanguage 0.6 - 64 bit
    When I start the bq Evaluation Software, I get these error messages:
    1.- "The detected device is not compatible with this application! Proceed at your own risk"
    2.- A "Communication Error" message appears at the bottom left side of the "Texas Instrument bq Gas Gauge Evaluation Software - bq20z80..."
    Any help will be greatly appreciated.
    Report Abuse
    • Reply
  • Onyx Ahiakwo
    Posted by Onyx Ahiakwo
    on Jan 08 2013 15:44 PM
    Intellectual2495 points
    hi Jose,
    I suggest re-installing the EV2300 drivers for 64 Bit windows from this link http://e2e.ti.com/support/power_management/battery_management/m/videos__files/458983.aspx
    install as an administrator, then restart your system .Let's see if this works for you.
    regards
    Onyx
    Report Abuse
    • Reply
  • JAG
    Posted by JAG
    on Jan 08 2013 18:16 PM
    Prodigy60 points
    Hi Onyx,
    Thank you very much for your suggestion.
    I installed the 64 bit driver as instructed and restarted the PC. It did not work.
    Any other idea?
    Report Abuse
    • Reply
  • Onyx Ahiakwo
    on Jan 09 2013 11:40 AM
    Connect your cells to the evm (or use a cell simulator- 1 k resistors and a power supply(see  document-SLUA 421A:quick-start guide for bq20zxx family gas gauges for steps on how to do this) )  and momentarily short pack+ and 4p terminal on the EVM. This will wake the device from shut-down mode. I believe this is why you are seeing the communication error.
    Report Abuse
    • Reply
  • JAG
    Posted by JAG
    on Jan 09 2013 14:57 PM
    Prodigy60 points
    Hi Onyx,
    I'm sorry I was not clear about this, but I have done that long time ago.
    Report Abuse
    • Reply
  • Onyx Ahiakwo
    on Jan 09 2013 16:56 PM
    Jose,
    I tested a 20z80 board here on a windows 7 comp.  After momentarily shorting the pack + and 4P terminal ,communication was ok. You will have to troubleshoot the EVM to make sure your IC is not damaged. Look up the IC pins and  their respective electrical characteristics on the data sheet to know what values to expect when troubleshooting. If the IC is damaged, then you will need to replace it .
    thanks
    Onyx
    Report Abuse
    • Reply
  • JAG
    Posted by JAG
    on Jan 15 2013 16:16 PM
    Verified Answer
    Verified by Onyx Ahiakwo
    Prodigy60 points
    Hi Onyx,
    Finally the EV2300 is working. This is what I have done:
    1.- Updated the driver as per your recommendation.
     2.- Modified EV2300 changing resistor R34 from 100K to 50K
    Explanation:
    After changing the driver, the EV2300 was not recognized consistently by Windows when the USB cable was plugged into the PC. When the unit failed to be recognized by Windows the Red LED (D20) was permanently turned ON. If the USB cable was unplugged and quickly plugged back, the unit will work properly.
    Reducing the time to enable the 3.3V LDO, decreasing R34 solved the problem.
    Thanks for your help.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
