My customer is starting to use TI’s BQ3060 in some of thier products and have run across a bit of a problem that I’m hoping you might be able to help me out with, or at least point me in the right direction. The issue they are having is getting the unseal keys to access the device. These are referenced in some of their literature, but can’t find what the actual key values are.
Any help would be greatly appreciated.
If the pack is unsealed, the customer can use the extended SBS command 0x60 to read what the unseal key is. The same command can be used to change the unseal key to a different value.
