• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Gas Gauge Forum » Voltage supply for BQ2040
Share
Battery Management
  • Forums
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Charles Lambert
Posted by Charles Lambert
on Jul 16 2012 07:05 AM
Prodigy30 points
My question is about BQ2040: http://www.ti.com/lit/ds/symlink/bq2040.pdf
Can I directly power the component using 28 NiMH cells and a 2N7002 FET, whereas the Chart 1 page 3 stops at 12 NiMH cells ?
If yes, what would be the ideal values for R4, R5, R11 ?
bq2040 cell supply
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Charles Lambert
    on Jul 24 2012 02:38 AM
    Prodigy30 points
    Any help ?
    Report Abuse
    • Reply
  • Garry R Elder
    Posted by Garry R Elder
    on Aug 09 2012 20:33 PM
    Verified Answer
    Verified by Charles Lambert
    Intellectual2020 points
    Hi Charles,
      For voltages that high an LDO is typically used to provide a solid Vcc.
    As for the values of R4 and R5, the formula is in the DS.
    Voltage Thresholds
    In conjunction with monitoring VSR for charge/discharge currents, the bq2040 monitors the battery potential
    through the SB pin. The voltage potential is determined through a resistor-divider network per the following
    equation:
    R5 / R4 = (MBV / 2.25) -1
    where MBV is the maximum battery voltage, R5 is connected to the positive battery terminal, and R4 is connected to the negative battery terminal. R5/R4 should be
    rounded to the next higher integer. The voltage at the SB pin (VSB) should never exceed 2.4V.
    Also, the total of R4 + R5 should be no more than ~1M
    Best regards
    Garry
    Report Abuse
    • Reply
  • Charles Lambert
    on Aug 10 2012 10:06 AM
    Prodigy30 points
    thank you for the answer,
    I will use R4 = 34K, R5 = 909K, R11 = 3,3M and keep informed anyone following this post if it doesn't work as expected.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
