• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Gas Gauge Forum » BQ77PL900, reduce Cell Balance Time, Do I have to input external power for charging at first time?
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Jin Kim
Posted by Jin Kim
on Jul 30 2012 04:25 AM
Intellectual270 points
Hello TIer
I have two question about BQ77PL900 EVM.
1. What do I have to do for reduce cell balance time as below.
2. Do I have to input a power souce for charging to Pack+/Pack- at first time?
When I connected only battery cells, Host PC did not detect the BQ77PL900
If I connect a power to the Pack+/Pack-, then EVM can be detected by Host PC.
Please answer me. or if you have any question about this, please tell me.
bq77PL900 power to PACK+/PACK- reduce balancing time
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • WM5295
    Posted by WM5295
    on Jul 30 2012 08:56 AM
    Verified Answer
    Verified by Jin Kim
    Expert3270 points
    1. System parameters must be adjusted and trade-offs made to get a minimum balance time. The figure refers to standalone balancing. Actual balancing occurs in the time between ta and tb, tc and td, ....  The OVH level must be set high enough to allow balancing to occur.  If OVH = 0, the part recovers very quickly and basically cycles the CHG on and off as it recovers and evaluates the new OV condition, until the cell remains above OV long enough to allow some balancing.  This will extend overall balance time. If the charge current is high, the cell resistance and the V = I x R drop of the cell may be a large part of the OVH range, so the time available for balance may be reduced and the total balance time extended.  A higher balance current will help reduce time until it creates a V = I x R drop which causes recovery early.  So a moderate balance current may be better than a high one to keep overall balancing time low.  The differences in the cells is also important.  A cell with a high resistance will have more voltage drop during charge and balance and alter balancing as described above.  The balancing will be more effective at maintaining balance on a pack that is slowly varying over time than adjusting a pack assembled with cell mis-match. This should be considered when designing a balancing test.
    Host mode balancing does not have the limitations of the standalone algorithm pictures above.  The host can recognize the current and voltages, and could adjust for I x R drops of the cells as well as start and end balance before the OV level is reached.. The host could also balance after charge current has stopped, or stop charge current to check voltages and balance if the charger allows it. Host mode balancing of course requires the extra effort and cost of the host, calibration, algorithm and code development.
    2. Yes, the device requires a voltage on PACK to wake up the first time or after shutdown.  Please see the "Initialization" section, page 29 of the bq77PL900 datasheet, the "VI(STARTUP)" in the recommended operating conditions, and the right side of figure 15, page 27 to help explain this part of the device operation. This is the reason for step 3 of section 4.5 of the EVM user's guide.
    bq77PL900
    Report Abuse
    • Reply
  • Jin Kim
    Posted by Jin Kim
    on Aug 01 2012 09:39 AM
    Thank you for your kindness answer.
    It was very helpful for us
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
