• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Gas Gauge Forum » USB-to-GPIO does not function
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Dmitry Vasilenko - Arrow
Posted by Dmitry Vasilenko - Arrow
on Aug 28 2012 01:01 AM
Expert1130 points
Hi, we have received the USB-to-GPIO adapter along with BQ24180EVM. It seems that the USB-to-GPIO does not function: computer sees the device as USB\VID_0451&PID_5F00&REV_0100 but the BQ24180EVM software does not see the end-EVM, as well the SDA and SCL lines of the USB-to-GPIO are showing only stable voltage 3.42V.
USB-TO-GPIO
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Dmitry Vasilenko - Arrow
    on Aug 30 2012 07:43 AM
    Verified Answer
    Verified by Dmitry Vasilenko - Arrow
    Expert1130 points
    Hi, it looks that the software for BQ24180EVM is not functioning. The BQ24272EVM was working with the adapter.
    Report Abuse
    • Reply
  • Jeff F
    Posted by Jeff F
    on Aug 30 2012 09:47 AM
    Mastermind22355 points
    The USB-to-GPIO adapters are notoriously unreliable.  I suggest trying a different adapter.  Then I suggest downloading the latest bq24180EVM software from the EVM website.  In the meantime, I will order a bq24180EVM, as I do not have one in stock, and confirm that the software works on that EVM.
    Report Abuse
    • Reply
    on Aug 31 2012 00:17 AM
    Expert1130 points
    Hi, Jeff, we have used the software downloaded from the web. Besides, the BQ24272EVM works with this adapter. Please check the EVM software in your lab and let us know!
    Report Abuse
    • Reply
  • Jeff F
    Posted by Jeff F
    on Aug 31 2012 09:58 AM
    Is the PC/laptop on which you are running this software a Windows 7, Windows Vista or Windows XP machine?
    Report Abuse
    • Reply
    on Sep 03 2012 06:58 AM
    Expert1130 points
    Hi, we're using windows 7 Professional.
    Report Abuse
    • Reply
  • Jeff F
    Posted by Jeff F
    on Sep 04 2012 11:38 AM
    bq24180_software.zip
    Attached files are Win 7 compatible.
    Report Abuse
    • Reply
    on Sep 06 2012 04:17 AM
    Expert1130 points
    HI,
    we have tested the software you provided. It's working better: it sees the USB-GPIO adpater at least. However there is a problem writing some registers (2d - ok, but 3d and 6th not possible) as well as sometimes the customer sees a mistake when choosing the R_sense.
    Report Abuse
    • Reply
  • Jeff F
    Posted by Jeff F
    on Sep 07 2012 14:53 PM
    The current sense resistor setting must match the physical current sense resistor in the circuit and measured currents will not match those per the register settings.
    The maximum battery regulation voltage and maximum charge current settings can only be changed immediately following VBAT rising above the VSHORT threshold and before any other WRITE.
    I do not understand what you mean by 2d, 3d and 6th.
    Please ensure that if you are using the AUTOREAD feature, you set it slow enough (20sec) that you can actually make a change to one of the registers before the next read.
    Report Abuse
    • Reply
    on Sep 10 2012 08:20 AM
    Verified Answer
    Expert1130 points
    Jeff, thank you for the tipps.
    The numbers for registers correspond to the numbers of the BQ24180 registers R01, R02 etc, that could be modified from the software dialog. I hve discussed the issue with the customer and we found out, that the reasons for R02 to be chengeable and R03, 06 to be unchangeable are described in the datasheet.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
