Ok, still having some low volume production pains. I have a quantity of 60 or so batteries that after programming data flash and doing IT enable and sealing, FAS is set but SS is not set. attempting to use the FAS key to unseal does not create any response. of i use the 0x41 reset command SS will set, and it responds to the SS key to remove the SS flag, but FAS is still non responsive.
Any ideas, or other information you guys would need for this? I can provide a sample battery to a TI apps engineer if that is helpful.
