We are using the BQ78350 with the BQ76940 and the documentation for the BQ769x0 says that we need to write to the SYS_STAT register to clear the bit that set the ALERT pin.
The 0x58 SBS command from the BQ78350 does not work since it is a read-only register.
How would I reset the bits so the ALERT signal is cleared?
