Hi Sir/Madam,
Can you please explain me the purpose of Rsense resistor which is connected between SRP & SRN pin of BQ27541-G1?.
The resistance range mentioned in data sheet is around 5mOhm to 20mOhm, what is the effect of this value determination? (if 5mOhm means what will be happen, 20mOhm means what will be happen?)
What will be happened if i am shorting SRP pin with SRN pin?
Whether this will have control over charging current of a battery?
Expecting your faster reply,
Ganesh.
