Hello, in the datasheet it says you can only write one byte at a time, if you attempt an incremental write all extra bytes will be be NACK.
This doesn't seem to be the case.
When I use the BQEV software I can send 2 byte words to an address and there is no NACK.
I am trying to unseal a pack and I can only unseal it using the BQEV software when I send 16bit words, these apparently can't be sent according to the data sheet.
The scope shows, AA, 00 , 14, 04, this is clearly a multi byte message. Am I misunderstanding the datasheet?
If I send them one byte at a time to address 0 then address 1, the unseal doesn't work.
Perhaps you can shead some light on this.
Morgan
