I am using a bq20z655-r1 and Saft cells MP174565 4800mAh
I recently reinstalled the bqEVSW from: www.ti.com/.../sluc304
At I start of bqCHEM : Warning! Communication with target device can not be established...
Do you wish to ignore future errors?I click {NO] - (However I can read and write using Data Flash and .gg files or read with SBS)
click [Yes: enable Chemistry Selection],
scroll and select MP174565 4800mAh then click [OK Update fuel gauge Data Flash],
Error at Match_Template : Cannot find the Device encr file click [OK],
Chem file did not match any template. Please get in touch with TI to sort this out. click [OK],
Proceed at your own risk click [OK],
Proceeding to Program Chem file .... click [OK],
Fail read verify. Abort SubClass83 programming click [OK],
Fail read verify. Abort SubClass84 programming click [OK],
... on and on
Fail read verify. Abort SubClass95 programming click [OK],
Cannot found ENCR file. IT Cfg will not be updated click [OK],
Jon
