I'm having problems in calculating the chemistry ID of a battery. The Mathcad software loads the data, but doesn't return a result...
Can somebody help me?log_5A.log
I hadn't understanded that the log should only include the discharging data, that isn't very clear in the chemselect_cont.pdf file.
Another question, in the results table the best ChemID is 319, why did you replied that it was 3180? Did you obtained different results?
0 | 1 | 2 | |
0 | 2.64575 | 319 | 0.358663 |
1 | 2.867901 | 3524 | 0.550945 |
2 | 2.976652 | 345 | 0.658106 |
3 | 3.027609 | 3180 | 0.280826 |
Thanks for all the help.
Using th Mathcad software i've obtain the chemID of 1298 for a battery. However this chemID isn't listed in the bqstudio software (version 1.3.40) for the BQ78350 BMS.
What should i do regarding the non listed chemID? Can someone please confirm that the chemID 1298 is the best fit for the attached data?
