I've made my own BQ40Z60 board, which is the same as BQ40Z60 excepted the following change :
- traditional fuse (no external burning)
- no 2nd degree protection (BQ294700)
- I want to charge at 1A and I want to improve resolution, so Rchg=30mOhms and Rsns=20mOhms (I set min voltage output=6283 / Voltage resolution = 25 / Current resolution =13 / max current register (1A) = 77)
- fixed in 3S configuration
The forum help me to resolve some problems (default init state = no charge, pin21 should not be floating,..)
Now my problem is that the charger is starting charge at about 0.87A (show on lab power supply and control with an oscilloscope) : for 1A requested, seem to be OK. But 9 seconds later going to 0A. 3 second later re-going to 0.87A, and it does this round and round...
After some Log, it seems to measure more current than it should (see. Log in attachment : current about 4A max and AvgCurr about 2A max).
I tried on 2 different boards, and see the same results… so it shouldn’t be a manufacturing problem.
Do you find something wrong in my configuration ?
Hubert
* Texas Instruments Data Flash File
* File created Tue Apr 26 11:10:55 2016
* Device Number 4600
* Firmware Version 0.13
* Build Number 19
* Order Number 0
* bqz Device Number 4600
* bqz Firmware Version 0.13
* bqz Build Number 19
* Field Order: Class name, Subclass name, Parameter name, Parameter Value, Display Units
Calibration,Voltage,Cell Gain,12101,-
Calibration,Voltage,Pack Gain,49669,-
Calibration,Voltage,BAT Gain,48936,-
Calibration,Current,CC Gain,5.006,mOhm
Calibration,Current,Capacity Gain,5.006,mOhm
Calibration,Current Offset,CC Offset,0,-
Calibration,Current Offset,Coulomb Counter Offset Samples,64,-
Calibration,Current Offset,Board Offset,0,-
Calibration,Current Offset,CC Auto Config,03,hex
Calibration,Current Offset,CC Auto Offset,0,-
Calibration,Temperature,Internal Temp Offset,0,degC
Calibration,Temperature,External1 Temp Offset,0,degC
Calibration,Temperature,External2 Temp Offset,0,degC
Calibration,Temperature,External3 Temp Offset,0,degC
Calibration,Temperature,External4 Temp Offset,0,degC
Calibration,Internal Temp Model,Int Gain,-12143,-
Calibration,Internal Temp Model,Int base offset,6232,-
Calibration,Internal Temp Model,Int Minimum AD,0,-
Calibration,Internal Temp Model,Int Maximum Temp,6232,0.1degK
Calibration,Cell Temperature Model,Coeff a1,-11130,-
Calibration,Cell Temperature Model,Coeff a2,19142,-
Calibration,Cell Temperature Model,Coeff a3,-19262,-
Calibration,Cell Temperature Model,Coeff a4,28203,-
Calibration,Cell Temperature Model,Coeff a5,892,-
Calibration,Cell Temperature Model,Coeff b1,328,-
Calibration,Cell Temperature Model,Coeff b2,-605,-
Calibration,Cell Temperature Model,Coeff b3,-2443,-
Calibration,Cell Temperature Model,Coeff b4,4696,-
Calibration,Cell Temperature Model,Rc0,11703,-
Calibration,Cell Temperature Model,Adc0,11703,-
Calibration,Cell Temperature Model,Rpad,0,-
Calibration,Cell Temperature Model,Rint,0,-
Calibration,Fet Temperature Model,Coeff a1,-11130,-
Calibration,Fet Temperature Model,Coeff a2,19142,-
Calibration,Fet Temperature Model,Coeff a3,-19262,-
Calibration,Fet Temperature Model,Coeff a4,28203,-
Calibration,Fet Temperature Model,Coeff a5,892,-
Calibration,Fet Temperature Model,Coeff b1,328,-
Calibration,Fet Temperature Model,Coeff b2,-605,-
Calibration,Fet Temperature Model,Coeff b3,-2443,-
Calibration,Fet Temperature Model,Coeff b4,4696,-
Calibration,Fet Temperature Model,Rc0,11703,-
Calibration,Fet Temperature Model,Adc0,11703,-
Calibration,Fet Temperature Model,Rpad,0,-
Calibration,Fet Temperature Model,Rint,0,-
Calibration,Filter,Cell Voltage 1,145,-
Calibration,Filter,Cell Voltage 2,145,-
Calibration,Filter,Cell Voltage 3,145,-
Calibration,Filter,Cell Voltage 4,145,-
Calibration,Filter,Pack Voltage Out,10,-
Calibration,Filter,Direct Battery Voltage,10,-
Calibration,Filter,Summed Battery Voltage,145,-
Calibration,Filter,Cell Temperature,145,-
Calibration,Filter,FET Temperature,145,-
Calibration,Current Deadband,Deadband,3,mA
Calibration,Current Deadband,Coulomb Counter Deadband,9,116nV
Settings,Protection,Protection Configuration,00,hex
Settings,Protection,Enabled Protections A,ff,hex
Settings,Protection,Enabled Protections B,7f,hex
Settings,Protection,Enabled Protections C,fd,hex
Settings,Protection,Enabled Protections D,2f,hex
Settings,Permanent Failure,Enabled PF A,00,hex
Settings,Permanent Failure,Enabled PF B,00,hex
Settings,Permanent Failure,Enabled PF C,00,hex
Settings,Permanent Failure,Enabled PF D,00,hex
Settings,Configuration,Charging Configuration,00,hex
Settings,Configuration,Temperature Enable,01,hex
Settings,Configuration,Temperature Mode,00,hex
Settings,Configuration,DA Configuration,06,hex
Settings,Configuration,FET Options,00,hex
Settings,Configuration,Sbs Gauging Configuration,04,hex
Settings,Configuration,Sbs Configuration,20,hex
Settings,Configuration,Power Config,00,hex
Settings,Configuration,IO Config,80,hex
Settings,Configuration,LED Configuration,04,hex
Settings,Configuration,SOC Flag Config A,0c8c,hex
Settings,Configuration,SOC Flag Config B,8c,hex
Settings,Configuration,Balancing Configuration,01,hex
Settings,Configuration,IT Gauging Configuration,d4fe,hex
Settings,AFE,AFE Protection Control,70,hex
Settings,AFE,ZVCHG Exit Threshold,2200,mV
Settings,Fuse,PF Fuse A,00,hex
Settings,Fuse,PF Fuse B,00,hex
Settings,Fuse,PF Fuse C,00,hex
Settings,Fuse,PF Fuse D,00,hex
Settings,Fuse,Min Blow Fuse Voltage,3500,mV
Settings,Fuse,Fuse Blow Timeout,30,s
Settings,BTP,Init Discharge Set,150,mAH
Settings,BTP,Init Charge Set,175,mAH
Settings,Manufacturing,Mfg Status init,0618,hex
Protections,CUV,Threshold,2500,mV
Protections,CUV,Delay,2,s
Protections,CUV,Recovery,3000,mV
Protections,CUVC,Threshold,2400,mV
Protections,CUVC,Delay,2,s
Protections,CUVC,Recovery,3000,mV
Protections,COV,Threshold Low Temp,4300,mV
Protections,COV,Threshold Standard Temp,4300,mV
Protections,COV,Threshold High Temp,4300,mV
Protections,COV,Threshold Rec Temp,4300,mV
Protections,COV,Delay,2,s
Protections,COV,Recovery Low Temp,3900,mV
Protections,COV,Recovery Standard Temp,3900,mV
Protections,COV,Recovery High Temp,3900,mV
Protections,COV,Recovery Rec Temp,3900,mV
Protections,ACOV,Threshold,18000,mV
Protections,ACOV,Recovery,17000,mV
Protections,OCC1,Threshold,5000,mA
Protections,OCC1,Delay,6,s
Protections,OCC2,Threshold,6000,mA
Protections,OCC2,Delay,3,s
Protections,OCC,Recovery Threshold,-200,mA
Protections,OCC,Recovery Delay,5,s
Protections,OCD1,Threshold,-1000,mA
Protections,OCD1,Delay,6,s
Protections,OCD2,Threshold,-1500,mA
Protections,OCD2,Delay,3,s
Protections,OCD,Recovery Threshold,200,mA
Protections,OCD,Recovery Delay,5,s
Protections,AOLD,Latch Limit,0,-
Protections,AOLD,Counter Dec Delay,10,s
Protections,AOLD,Recovery,5,s
Protections,AOLD,Reset,15,s
Protections,AOLD,Threshold,f8,hex
Protections,ASCC,Latch Limit,0,-
Protections,ASCC,Counter Dec Delay,10,s
Protections,ASCC,Recovery,5,s
Protections,ASCC,Reset,15,s
Protections,ASCC,Threshold,72,hex
Protections,ASCD,Latch Limit,0,-
Protections,ASCD,Counter Dec Delay,10,s
Protections,ASCD,Recovery,5,s
Protections,ASCD,Reset,15,s
Protections,ASCD,Threshold 1,72,hex
Protections,ASCD,Threshold 2,e2,hex
Protections,OTC,Threshold,55.0,1degC
Protections,OTC,Delay,2,s
Protections,OTC,Recovery,50.0,1degC
Protections,OTD,Threshold,60.0,1degC
Protections,OTD,Delay,2,s
Protections,OTD,Recovery,55.0,1degC
Protections,OTF,Threshold,80.0,1degC
Protections,OTF,Delay,2,s
Protections,OTF,Recovery,65.0,1degC
Protections,UTC,Threshold,0,1degC
Protections,UTC,Delay,2,s
Protections,UTC,Recovery,5.0,1degC
Protections,UTD,Threshold,-20.0,1degC
Protections,UTD,Delay,2,s
Protections,UTD,Recovery,-15.0,1degC
Protections,COT,Recovery Delay,5,s
Protections,HWD,Delay,10,s
Protections,PTO,Charge Threshold,2000,mA
Protections,PTO,Suspend Threshold,1800,mA
Protections,PTO,Delay,1800,s
Protections,PTO,Reset,2,mAh
Protections,CTO,Charge Threshold,500,mA
Protections,CTO,Suspend Threshold,400,mA
Protections,CTO,Delay,54000,s
Protections,CTO,Reset,2,mAh
Protections,OC,Threshold,300,mAh
Protections,OC,Recovery,2,mAh
Protections,OC,RSOC Recovery,90,%
Protections,CHGV,Threshold,500,mV
Protections,CHGV,Delay,30,s
Protections,CHGV,Recovery,-500,mV
Protections,CHGC,Threshold,500,mA
Protections,CHGC,Delay,8,s
Protections,CHGC,Recovery Threshold,100,mA
Protections,CHGC,Recovery Delay,2,s
Protections,PCHGC,Threshold,50,mA
Protections,PCHGC,Delay,2,s
Protections,PCHGC,Recovery Threshold,10,mA
Protections,PCHGC,Recovery Delay,2,s
Permanent Fail,SUV,Threshold,2200,mV
Permanent Fail,SUV,Delay,5,s
Permanent Fail,SOV,Threshold,4500,mV
Permanent Fail,SOV,Delay,5,s
Permanent Fail,SOCC,Threshold,10000,mA
Permanent Fail,SOCC,Delay,5,s
Permanent Fail,SOCD,Threshold,-10000,mA
Permanent Fail,SOCD,Delay,5,s
Permanent Fail,SOT,Threshold,65.0,1degC
Permanent Fail,SOT,Delay,5,s
Permanent Fail,SOTF,Threshold,100.0,1degC
Permanent Fail,SOTF,Delay,5,s
Permanent Fail,Open Thermistor,Threshold,-50.0,1degC
Permanent Fail,Open Thermistor,Delay,5,s
Permanent Fail,Open Thermistor,Fet Delta,20.0,1degC
Permanent Fail,Open Thermistor,Cell Delta,20.0,1degC
Permanent Fail,QIM,Delta Threshold,15.0,%
Permanent Fail,QIM,Delay,2,updates
Permanent Fail,CB,Max Threshold,240,h
Permanent Fail,CB,Delta Threshold,40,h
Permanent Fail,CB,Delay,2,cycles
Permanent Fail,VIMR,Check Voltage,3500,mV
Permanent Fail,VIMR,Check Current,10,mA
Permanent Fail,VIMR,Delta Threshold,500,mV
Permanent Fail,VIMR,Delta Delay,5,s
Permanent Fail,VIMR,Duration,100,s
Permanent Fail,VIMA,Check Voltage,3700,mV
Permanent Fail,VIMA,Check Current,50,mA
Permanent Fail,VIMA,Delta Threshold,200,mV
Permanent Fail,VIMA,Delay,5,s
Permanent Fail,IMP,Delta Threshold,300,%
Permanent Fail,IMP,Max Threshold,400,%
Permanent Fail,IMP,Ra Update Counts,2,counts
Permanent Fail,CD,Threshold,0,mAh
Permanent Fail,CD,Delay,2,cycles
Permanent Fail,CFET,OFF Threshold,5,mA
Permanent Fail,CFET,OFF Delay,5,s
Permanent Fail,DFET,OFF Threshold,-50,mA
Permanent Fail,DFET,OFF Delay,5,s
Permanent Fail,FUSE,Threshold,5,mA
Permanent Fail,FUSE,Delay,5,s
Permanent Fail,AFER,Threshold,100,-
Permanent Fail,AFER,Delay Period,2,s
Permanent Fail,AFER,Compare Period,5,s
Permanent Fail,AFEC,Threshold,100,-
Permanent Fail,AFEC,Delay Period,5,s
Permanent Fail,2LVL,Delay,5,s
Permanent Fail,OPNCELL,Threshold,5000,mV
Permanent Fail,OPNCELL,Delay,5,s
Advanced Charge Algorithm,Charger,Minimum Voltage Output,6283,mV
Advanced Charge Algorithm,Charger,Voltage Resolution,25,mV
Advanced Charge Algorithm,Charger,LCHG Current Resolution,3,mA
Advanced Charge Algorithm,Charger,Current Resolution,13,mA
Advanced Charge Algorithm,Charger,Max Current Register,77,-
Advanced Charge Algorithm,Charger,Vacp Hysteresis,0,mV
Advanced Charge Algorithm,Temperature Ranges,T1 Temp,0,degC
Advanced Charge Algorithm,Temperature Ranges,T2 Temp,12,degC
Advanced Charge Algorithm,Temperature Ranges,T5 Temp,20,degC
Advanced Charge Algorithm,Temperature Ranges,T6 Temp,25,degC
Advanced Charge Algorithm,Temperature Ranges,T3 Temp,30,degC
Advanced Charge Algorithm,Temperature Ranges,T4 Temp,55,degC
Advanced Charge Algorithm,Temperature Ranges,Hysteresis Temp,1,degC
Advanced Charge Algorithm,Low Temp Charging,Voltage,4000,mV
Advanced Charge Algorithm,Low Temp Charging,Current Low,132,mA
Advanced Charge Algorithm,Low Temp Charging,Current Med,352,mA
Advanced Charge Algorithm,Low Temp Charging,Current High,264,mA
Advanced Charge Algorithm,Standard Temp Charging,Voltage,4200,mV
Advanced Charge Algorithm,Standard Temp Charging,Current Low,900,mA
Advanced Charge Algorithm,Standard Temp Charging,Current Med,1000,mA
Advanced Charge Algorithm,Standard Temp Charging,Current High,1000,mA
Advanced Charge Algorithm,High Temp Charging,Voltage,4000,mV
Advanced Charge Algorithm,High Temp Charging,Current Low,450,mA
Advanced Charge Algorithm,High Temp Charging,Current Med,500,mA
Advanced Charge Algorithm,High Temp Charging,Current High,500,mA
Advanced Charge Algorithm,Rec Temp Charging,Voltage,4100,mV
Advanced Charge Algorithm,Rec Temp Charging,Current Low,1000,mA
Advanced Charge Algorithm,Rec Temp Charging,Current Med,1000,mA
Advanced Charge Algorithm,Rec Temp Charging,Current High,1000,mA
Advanced Charge Algorithm,Pre-Charging,Current,250,mA
Advanced Charge Algorithm,Maintenance Charging,Current,44,mA
Advanced Charge Algorithm,Voltage Range,Precharge Start Voltage,2500,mV
Advanced Charge Algorithm,Voltage Range,Charging Voltage Low,2900,mV
Advanced Charge Algorithm,Voltage Range,Charging Voltage Med,3600,mV
Advanced Charge Algorithm,Voltage Range,Charging Voltage High,4000,mV
Advanced Charge Algorithm,Voltage Range,Charging Voltage Hysteresis,0,mV
Advanced Charge Algorithm,Termination Config,Charge Term Taper Current,250,mA
Advanced Charge Algorithm,Termination Config,Charge Term Voltage,75,mV
Advanced Charge Algorithm,Charging Rate of Change,Current Rate,1,steps
Advanced Charge Algorithm,Charging Rate of Change,Voltage Rate,1,steps
Advanced Charge Algorithm,Cell Balancing Config,Bal Time/mAh Cell 1,367,s/mAh
Advanced Charge Algorithm,Cell Balancing Config,Bal Time/mAh Cell 2-4,514,s/mAh
Advanced Charge Algorithm,Cell Balancing Config,Min Start Balance Delta,3,mV
Advanced Charge Algorithm,Cell Balancing Config,Relax Balance Interval,18000,s
Advanced Charge Algorithm,Cell Balancing Config,Min Rsoc for Balancing,80,%
Gas Gauging,Current Thresholds,Dsg Current Threshold,100,mA
Gas Gauging,Current Thresholds,Chg Current Threshold,50,mA
Gas Gauging,Current Thresholds,Quit Current,10,mA
Gas Gauging,Current Thresholds,Dsg Relax Time,1,s
Gas Gauging,Current Thresholds,Chg Relax Time,60,s
Gas Gauging,Current Thresholds,Dsg Body Diode Protect Threshold,100,mA
Gas Gauging,Current Thresholds,Chg Body Diode Threshold,100,mA
Gas Gauging,Design,Design Capacity mAh,4400,mAh
Gas Gauging,Design,Design Capacity cWh,6336,cWh
Gas Gauging,Design,Design Voltage,10800,mV
Gas Gauging,Cycle,Cycle Count Percentage,90,%
Gas Gauging,FD,Set Voltage Threshold,3000,mV
Gas Gauging,FD,Clear Voltage Threshold,3100,mV
Gas Gauging,FD,Set % RSOC Threshold,0,%
Gas Gauging,FD,Clear % RSOC Threshold,5,%
Gas Gauging,FC,Set Voltage Threshold,4200,mV
Gas Gauging,FC,Clear Voltage Threshold,4100,mV
Gas Gauging,FC,Set % RSOC Threshold,100,%
Gas Gauging,FC,Clear % RSOC Threshold,95,%
Gas Gauging,TD,Set Voltage Threshold,3200,mV
Gas Gauging,TD,Clear Voltage Threshold,3300,mV
Gas Gauging,TD,Set % RSOC Threshold,6,%
Gas Gauging,TD,Clear % RSOC Treshold,8,%
Gas Gauging,TC,Set Voltage Threshold,4200,mV
Gas Gauging,TC,Clear Voltage Threshold,4100,mV
Gas Gauging,TC,Set % RSOC Threshold,100,%
Gas Gauging,TC,Clear % RSOC Threshold,95,%
Gas Gauging,State,Cycle Count,0,-
Gas Gauging,State,Qmax Cell 1,4400,mAh
Gas Gauging,State,Qmax Cell 2,4400,mAh
Gas Gauging,State,Qmax Cell 3,4400,mAh
Gas Gauging,State,Qmax Cell 4,4400,mAh
Gas Gauging,State,Qmax Pack,4400,mAh
Gas Gauging,State,Qmax Cycle Count,0,-
Gas Gauging,State,Update Status,04,-
Gas Gauging,State,Cell 1 Chg Voltage at EoC,4200,mV
Gas Gauging,State,Cell 2 Chg Voltage at EoC,4200,mV
Gas Gauging,State,Cell 3 Chg Voltage at EoC,4200,mV
Gas Gauging,State,Cell 4 Chg Voltage at EoC,4200,mV
Gas Gauging,State,Current at EoC,250,mA
Gas Gauging,State,Avg I Last Run,-2000,mA
Gas Gauging,State,Avg P Last Run,-3022,cW
Gas Gauging,State,Delta Voltage,0,mV
Gas Gauging,State,Temp k,1.00,degC/256mW
Gas Gauging,State,Temp a,1000,-
Gas Gauging,State,Max Avg I Last Run,-2000,mA
Gas Gauging,State,Max Avg P Last Run,-3022,cW
Gas Gauging,IT Cfg,Load Select,7,-
Gas Gauging,IT Cfg,Load Mode,0,-
Gas Gauging,IT Cfg,Design Resistance,42,mOhms
Gas Gauging,IT Cfg,User Rate-mA,0,mA
Gas Gauging,IT Cfg,User Rate-cW,0,cW
Gas Gauging,IT Cfg,Reserve Cap-mAh,0,mAh
Gas Gauging,IT Cfg,Reserve Cap-cWh,0,cWh
Gas Gauging,IT Cfg,Pack Resistance,30,mOhms
Gas Gauging,IT Cfg,System Resistance,0,mOhms
Gas Gauging,IT Cfg,Ra Filter,50.0,%
Gas Gauging,IT Cfg,Ra Max Delta,15,%
Gas Gauging,IT Cfg,Reference Grid,4,-
Gas Gauging,IT Cfg,Resistance Parameter Filter,65142,-
Gas Gauging,IT Cfg,Near EDV Ra Param Filter,59220,-
Gas Gauging,IT Cfg,Qmax Delta,5,%
Gas Gauging,IT Cfg,Qmax Upper Bound,130,%
Gas Gauging,IT Cfg,Term Voltage,9000,mV
Gas Gauging,IT Cfg,Term V Hold Time,1,s
Gas Gauging,IT Cfg,Term Voltage Delta,300,mV
Gas Gauging,IT Cfg,Term Min Cell V,2800,mV
Gas Gauging,IT Cfg,Voltage Consistency Delta,300,mV
Gas Gauging,IT Cfg,Fast Scale Start SOC,10,%
Gas Gauging,Smoothing,Smooth Relax Time,1000,s
Gas Gauging,Condition Flag,Max Error Limit,100,%
Gas Gauging,Max Error,Time Cycle Equivalent,24,h
Gas Gauging,Max Error,Cycle Delta,0.05,%
Gas Gauging,SoH,SoH Load Rate,5.0,hour Rate
Gas Gauging,Turbo Cfg,Min Turbo Power,0,cW
Gas Gauging,Turbo Cfg,Max C Rate,-4,C
Gas Gauging,Turbo Cfg,High Frequency Resistance,31,mOhms
Gas Gauging,Turbo Cfg,Reserve Energy %,0,%
Power,Power,Valid Update Voltage,3500,mV
Power,Shutdown,Shutdown Voltage,1750,mV
Power,Shutdown,Shutdown Time,10,s
Power,Shutdown,PF Shutdown Voltage,1750,mV
Power,Shutdown,PF Shutdown Time,10,s
Power,Shutdown,Charger Present Threshold,3000,mV
Power,Sleep,Sleep Current,10,mA
Power,Sleep,Bus Timeout,5,s
Power,Sleep,Voltage Time,5,s
Power,Sleep,Current Time,20,s
Power,Sleep,Wake Comparitor,00,hex
Power,Ship,FET Off Time,10,s
Power,Ship,Delay,20,s
Power,Ship,Auto Ship Time,1440,min
Power,Power Off,Debounce,4,250ms
Power,Power Off,Timeout,30,min
Power,Manual FET Control,MFC Delay,60,s
PF Status,Device Status Data,Safety Alert A,00,hex
PF Status,Device Status Data,Safety Status A,00,hex
PF Status,Device Status Data,Safety Alert B,00,hex
PF Status,Device Status Data,Safety Status B,00,hex
PF Status,Device Status Data,Safety Alert C,00,hex
PF Status,Device Status Data,Safety Status C,00,hex
PF Status,Device Status Data,Safety Alert D,00,hex
PF Status,Device Status Data,Safety Status D,00,hex
PF Status,Device Status Data,PF Alert A,00,hex
PF Status,Device Status Data,PF Status A,00,hex
PF Status,Device Status Data,PF Alert B,00,hex
PF Status,Device Status Data,PF Status B,00,hex
PF Status,Device Status Data,PF Alert C,00,hex
PF Status,Device Status Data,PF Status C,00,hex
PF Status,Device Status Data,PF Alert D,00,hex
PF Status,Device Status Data,PF Status D,00,hex
PF Status,Device Status Data,Fuse Flag,0000,hex
PF Status,Device Status Data,Operation Status A,0000,hex
PF Status,Device Status Data,Operation Status B,0000,hex
PF Status,Device Status Data,Temp Range,00,hex
PF Status,Device Status Data,Charging Status A,00,hex
PF Status,Device Status Data,Charging Status B,00,hex
PF Status,Device Status Data,Charger Status,00,hex
PF Status,Device Status Data,Gauging Status,00,hex
PF Status,Device Status Data,IT Status,0000,hex
PF Status,Device Voltage Data,Cell 1 Voltage,0,mV
PF Status,Device Voltage Data,Cell 2 Voltage,0,mV
PF Status,Device Voltage Data,Cell 3 Voltage,0,mV
PF Status,Device Voltage Data,Cell 4 Voltage,0,mV
PF Status,Device Voltage Data,Battery Direct Voltage,0,mV
PF Status,Device Voltage Data,Pack Voltage,0,mV
PF Status,Device Current Data,Current,0,mA
PF Status,Device Temperature Data,Internal Temperature,-273.2,degC
PF Status,Device Temperature Data,External 1 Temperature,-273.2,degC
PF Status,Device Temperature Data,External 2 Temperature,-273.2,degC
PF Status,Device Temperature Data,External 3 Temperature,-273.2,degC
PF Status,Device Temperature Data,External 4 Temperature,-273.2,degC
PF Status,Device Gauging Data,Cell 1 Dod0,0,-
PF Status,Device Gauging Data,Cell 2 Dod0,0,-
PF Status,Device Gauging Data,Cell 3 Dod0,0,-
PF Status,Device Gauging Data,Cell 4 Dod0,0,-
PF Status,Device Gauging Data,Passed Charge,0,mAh
PF Status,AFE Regs,AFE Interrupt Status,00,hex
PF Status,AFE Regs,AFE FET Status,00,hex
PF Status,AFE Regs,AFE RXIN,00,hex
PF Status,AFE Regs,AFE Latch Status,00,hex
PF Status,AFE Regs,AFE Interrupt Enable,00,hex
PF Status,AFE Regs,AFE FET Control,00,hex
PF Status,AFE Regs,AFE RXIEN,00,hex
PF Status,AFE Regs,AFE RLOUT,00,hex
PF Status,AFE Regs,AFE RHOUT,00,hex
PF Status,AFE Regs,AFE RHINT,00,hex
PF Status,AFE Regs,AFE Cell Balance,00,hex
PF Status,AFE Regs,AFE AD/CC Control,00,hex
PF Status,AFE Regs,AFE ADC Mux,00,hex
PF Status,AFE Regs,AFE LED Output,00,hex
PF Status,AFE Regs,AFE State Control,00,hex
PF Status,AFE Regs,AFE LED/Wake Control,00,hex
PF Status,AFE Regs,AFE Protection Control,00,hex
PF Status,AFE Regs,AFE OCD,00,hex
PF Status,AFE Regs,AFE SCC,00,hex
PF Status,AFE Regs,AFE SCD1,00,hex
PF Status,AFE Regs,AFE SCD2,00,hex
PF Status,AFE Regs,AFE Charger Lock,00,
PF Status,AFE Regs,AFE Charger Voltage,00,
PF Status,AFE Regs,AFE Charger Current,00,
System Data,Manufacturer Data,Manufacturer Info A Length,32,-
System Data,Manufacturer Data,Manufacturer Info Block A01,61,Hex
System Data,Manufacturer Data,Manufacturer Info Block A02,62,Hex
System Data,Manufacturer Data,Manufacturer Info Block A03,63,Hex
System Data,Manufacturer Data,Manufacturer Info Block A04,64,Hex
System Data,Manufacturer Data,Manufacturer Info Block A05,65,Hex
System Data,Manufacturer Data,Manufacturer Info Block A06,66,Hex
System Data,Manufacturer Data,Manufacturer Info Block A07,67,Hex
System Data,Manufacturer Data,Manufacturer Info Block A08,68,Hex
System Data,Manufacturer Data,Manufacturer Info Block A09,69,Hex
System Data,Manufacturer Data,Manufacturer Info Block A10,6a,Hex
System Data,Manufacturer Data,Manufacturer Info Block A11,6b,Hex
System Data,Manufacturer Data,Manufacturer Info Block A12,6c,Hex
System Data,Manufacturer Data,Manufacturer Info Block A13,6d,Hex
System Data,Manufacturer Data,Manufacturer Info Block A14,6e,Hex
System Data,Manufacturer Data,Manufacturer Info Block A15,6f,Hex
System Data,Manufacturer Data,Manufacturer Info Block A16,70,Hex
System Data,Manufacturer Data,Manufacturer Info Block A17,71,Hex
System Data,Manufacturer Data,Manufacturer Info Block A18,72,Hex
System Data,Manufacturer Data,Manufacturer Info Block A19,73,Hex
System Data,Manufacturer Data,Manufacturer Info Block A20,74,Hex
System Data,Manufacturer Data,Manufacturer Info Block A21,75,Hex
System Data,Manufacturer Data,Manufacturer Info Block A22,76,Hex
System Data,Manufacturer Data,Manufacturer Info Block A23,77,Hex
System Data,Manufacturer Data,Manufacturer Info Block A24,7a,Hex
System Data,Manufacturer Data,Manufacturer Info Block A25,78,Hex
System Data,Manufacturer Data,Manufacturer Info Block A26,79,Hex
System Data,Manufacturer Data,Manufacturer Info Block A27,30,Hex
System Data,Manufacturer Data,Manufacturer Info Block A28,31,Hex
System Data,Manufacturer Data,Manufacturer Info Block A29,32,Hex
System Data,Manufacturer Data,Manufacturer Info Block A30,33,Hex
System Data,Manufacturer Data,Manufacturer Info Block A31,34,Hex
System Data,Manufacturer Data,Manufacturer Info Block A32,35,Hex
System Data,Integrity,Static DF Signature,0000,hex
System Data,Integrity,Static Chem DF Signature,5ec0,hex
System Data,Integrity,All DF Signature,0000,hex
SBS Configuration,Data,Remaining AH Cap. Alarm,300,mAh
SBS Configuration,Data,Remaining WH Cap. Alarm,432,cWh
SBS Configuration,Data,Remaining Time Alarm,10,min
SBS Configuration,Data,Initial Battery Mode,0081,hex
SBS Configuration,Data,Specification Information,0031,hex
SBS Configuration,Data,Manufacture Date,1980-1-1,date
SBS Configuration,Data,Serial Number,0001,hex
SBS Configuration,Data,Manufacturer Name,Texas Instruments,-
SBS Configuration,Data,Device Name,bq40z60,-
SBS Configuration,Data,Device Chemistry,LION,-
LED Support,LED Config,LED Delay,100,488us
LED Support,LED Config,LED Hold Time,4,s
LED Support,LED Config,CHG Thresh 1,25,%
LED Support,LED Config,CHG Thresh 2,50,%
LED Support,LED Config,CHG Thresh 3,75,%
LED Support,LED Config,CHG Thresh 4,100,%
LED Support,LED Config,DSG Thresh 1,25,%
LED Support,LED Config,DSG Thresh 2,50,%
LED Support,LED Config,DSG Thresh 3,75,%
LED Support,LED Config,DSG Thresh 4,100,%
Black Box,Safety Status,1st Status Status A,00,hex
Black Box,Safety Status,1st Status Status B,00,hex
Black Box,Safety Status,1st Safety Status C,00,hex
Black Box,Safety Status,1st Safety Status D,00,hex
Black Box,Safety Status,1st Time to Next Event,0,s
Black Box,Safety Status,2nd Status Status A,00,hex
Black Box,Safety Status,2nd Status Status B,00,hex
Black Box,Safety Status,2nd Safety Status C,00,hex
Black Box,Safety Status,2nd Safety Status D,00,hex
Black Box,Safety Status,2nd Time to Next Event,0,s
Black Box,Safety Status,3rd Status Status A,00,hex
Black Box,Safety Status,3rd Status Status B,00,hex
Black Box,Safety Status,3rd Safety Status C,00,hex
Black Box,Safety Status,3rd Safety Status D,00,hex
Black Box,Safety Status,3rd Time to Next Event,0,s
Black Box,PF Status,1st PF Status A,00,hex
Black Box,PF Status,1st PF Status B,00,hex
Black Box,PF Status,1st PF Status C,00,hex
Black Box,PF Status,1st PF Status D,00,hex
Black Box,PF Status,1st Time to Next Event,0,s
Black Box,PF Status,2nd PF Status A,00,hex
Black Box,PF Status,2nd PF Status B,00,hex
Black Box,PF Status,2nd PF Status C,00,hex
Black Box,PF Status,2nd PF Status D,00,hex
Black Box,PF Status,2nd Time to Next Event,0,s
Black Box,PF Status,3rd PF Status A,00,hex
Black Box,PF Status,3rd PF Status B,00,hex
Black Box,PF Status,3rd PF Status C,00,hex
Black Box,PF Status,3rd PF Status D,00,hex
Black Box,PF Status,3rd Time to Next Event,0,s
Lifetimes,Voltage,Cell 1 Max Voltage,0,mV
Lifetimes,Voltage,Cell 2 Max Voltage,0,mV
Lifetimes,Voltage,Cell 3 Max Voltage,0,mV
Lifetimes,Voltage,Cell 4 Max Voltage,0,mV
Lifetimes,Voltage,Cell 1 Min Voltage,32767,mV
Lifetimes,Voltage,Cell 2 Min Voltage,32767,mV
Lifetimes,Voltage,Cell 3 Min Voltage,32767,mV
Lifetimes,Voltage,Cell 4 Min Voltage,32767,mV
Lifetimes,Voltage,Max Delta Cell Voltage,0,mV
Lifetimes,Current,Max Charge Current,0,mA
Lifetimes,Current,Max Discharge Current,0,mA
Lifetimes,Current,Max Avg Dsg Current,0,mA
Lifetimes,Current,Max Avg Dsg Power,0,cW
Lifetimes,Temperature,Max Temp Cell,-128,degC
Lifetimes,Temperature,Min Temp Cell,127,degC
Lifetimes,Temperature,Max Delta Cell Temp,0,degC
Lifetimes,Temperature,Max Temp Int Sensor,-128,degC
Lifetimes,Temperature,Min Temp Int Sensor,127,degC
Lifetimes,Temperature,Max Temp Fet,-128,degC
Lifetimes,Safety Events,No Of COV Events,0,events
Lifetimes,Safety Events,Last COV Event,0,cycles
Lifetimes,Safety Events,No Of CUV Events,0,events
Lifetimes,Safety Events,Last CUV Event,0,cycles
Lifetimes,Safety Events,No Of OCD1 Events,0,events
Lifetimes,Safety Events,Last OCD1 Event,0,cycles
Lifetimes,Safety Events,No Of OCD2 Events,0,events
Lifetimes,Safety Events,Last OCD2 Event,0,cycles
Lifetimes,Safety Events,No Of OCC1 Events,0,events
Lifetimes,Safety Events,Last OCC1 Event,0,cycles
Lifetimes,Safety Events,No Of OCC2 Events,0,events
Lifetimes,Safety Events,Last OCC2 Event,0,cycles
Lifetimes,Safety Events,No Of AOLD Events,0,events
Lifetimes,Safety Events,Last AOLD Event,0,cycles
Lifetimes,Safety Events,No Of ASCD Events,0,events
Lifetimes,Safety Events,Last ASCD Event,0,cycles
Lifetimes,Safety Events,No Of ASCC Events,0,events
Lifetimes,Safety Events,Last ASCC Event,0,cycles
Lifetimes,Safety Events,No Of OTC Events,0,events
Lifetimes,Safety Events,Last OTC Event,0,cycles
Lifetimes,Safety Events,No Of OTD Events,0,events
Lifetimes,Safety Events,Last OTD Event,0,cycles
Lifetimes,Safety Events,No Of OTF Events,0,events
Lifetimes,Safety Events,Last OTF Event,0,cycles
Lifetimes,Charging Events,No Valid Charge Term,0,events
Lifetimes,Charging Events,Last Valid Charge Term,0,cycles
Lifetimes,Gauging Events,No Of Qmax Updates,0,events
Lifetimes,Gauging Events,Last Qmax Update,0,cycles
Lifetimes,Gauging Events,No Of Ra Updates,0,events
Lifetimes,Gauging Events,Last Ra Update,0,cycles
Lifetimes,Gauging Events,No Of Ra Disable,0,events
Lifetimes,Gauging Events,Last Ra Disable,0,cycles
Lifetimes,Power Events,No Of Shutdowns,0,events
Lifetimes,Cell Balancing,Cb Time Cell 1,0,h
Lifetimes,Cell Balancing,Cb Time Cell 2,0,h
Lifetimes,Cell Balancing,Cb Time Cell 3,0,h
Lifetimes,Cell Balancing,Cb Time Cell 4,0,h
Lifetimes,Time,Total Fw Runtime,0,h
Lifetimes,Time,Time Spent In UT,0,h
Lifetimes,Time,Time Spent In LT,0,h
Lifetimes,Time,Time Spent In STL,0,h
Lifetimes,Time,Time Spent In RT,0,h
Lifetimes,Time,Time Spent In STH,0,h
Lifetimes,Time,Time Spent In HT,0,h
Lifetimes,Time,Time Spent In OT,0,h
Ra Table,R_a0,Cell0 R_a flag,ff55,-
Ra Table,R_a0,Cell0 R_a 0,299,2^-10ohm
Ra Table,R_a0,Cell0 R_a 1,78,2^-10ohm
Ra Table,R_a0,Cell0 R_a 2,92,2^-10ohm
Ra Table,R_a0,Cell0 R_a 3,138,2^-10ohm
Ra Table,R_a0,Cell0 R_a 4,77,2^-10ohm
Ra Table,R_a0,Cell0 R_a 5,98,2^-10ohm
Ra Table,R_a0,Cell0 R_a 6,84,2^-10ohm
Ra Table,R_a0,Cell0 R_a 7,138,2^-10ohm
Ra Table,R_a0,Cell0 R_a 8,322,2^-10ohm
Ra Table,R_a0,Cell0 R_a 9,372,2^-10ohm
Ra Table,R_a0,Cell0 R_a 10,540,2^-10ohm
Ra Table,R_a0,Cell0 R_a 11,616,2^-10ohm
Ra Table,R_a0,Cell0 R_a 12,887,2^-10ohm
Ra Table,R_a0,Cell0 R_a 13,1709,2^-10ohm
Ra Table,R_a0,Cell0 R_a 14,8217,2^-10ohm
Ra Table,R_a1,Cell1 R_a flag,ff55,-
Ra Table,R_a1,Cell1 R_a 0,299,2^-10ohm
Ra Table,R_a1,Cell1 R_a 1,78,2^-10ohm
Ra Table,R_a1,Cell1 R_a 2,92,2^-10ohm
Ra Table,R_a1,Cell1 R_a 3,138,2^-10ohm
Ra Table,R_a1,Cell1 R_a 4,77,2^-10ohm
Ra Table,R_a1,Cell1 R_a 5,98,2^-10ohm
Ra Table,R_a1,Cell1 R_a 6,84,2^-10ohm
Ra Table,R_a1,Cell1 R_a 7,138,2^-10ohm
Ra Table,R_a1,Cell1 R_a 8,322,2^-10ohm
Ra Table,R_a1,Cell1 R_a 9,372,2^-10ohm
Ra Table,R_a1,Cell1 R_a 10,540,2^-10ohm
Ra Table,R_a1,Cell1 R_a 11,616,2^-10ohm
Ra Table,R_a1,Cell1 R_a 12,887,2^-10ohm
Ra Table,R_a1,Cell1 R_a 13,1709,2^-10ohm
Ra Table,R_a1,Cell1 R_a 14,8217,2^-10ohm
Ra Table,R_a2,Cell2 R_a flag,ff55,-
Ra Table,R_a2,Cell2 R_a 0,299,2^-10ohm
Ra Table,R_a2,Cell2 R_a 1,78,2^-10ohm
Ra Table,R_a2,Cell2 R_a 2,92,2^-10ohm
Ra Table,R_a2,Cell2 R_a 3,138,2^-10ohm
Ra Table,R_a2,Cell2 R_a 4,77,2^-10ohm
Ra Table,R_a2,Cell2 R_a 5,98,2^-10ohm
Ra Table,R_a2,Cell2 R_a 6,84,2^-10ohm
Ra Table,R_a2,Cell2 R_a 7,138,2^-10ohm
Ra Table,R_a2,Cell2 R_a 8,322,2^-10ohm
Ra Table,R_a2,Cell2 R_a 9,372,2^-10ohm
Ra Table,R_a2,Cell2 R_a 10,540,2^-10ohm
Ra Table,R_a2,Cell2 R_a 11,616,2^-10ohm
Ra Table,R_a2,Cell2 R_a 12,887,2^-10ohm
Ra Table,R_a2,Cell2 R_a 13,1709,2^-10ohm
Ra Table,R_a2,Cell2 R_a 14,8217,2^-10ohm
Ra Table,R_a3,Cell3 R_a flag,ff55,-
Ra Table,R_a3,Cell3 R_a 0,299,2^-10ohm
Ra Table,R_a3,Cell3 R_a 1,78,2^-10ohm
Ra Table,R_a3,Cell3 R_a 2,92,2^-10ohm
Ra Table,R_a3,Cell3 R_a 3,138,2^-10ohm
Ra Table,R_a3,Cell3 R_a 4,77,2^-10ohm
Ra Table,R_a3,Cell3 R_a 5,98,2^-10ohm
Ra Table,R_a3,Cell3 R_a 6,84,2^-10ohm
Ra Table,R_a3,Cell3 R_a 7,138,2^-10ohm
Ra Table,R_a3,Cell3 R_a 8,322,2^-10ohm
Ra Table,R_a3,Cell3 R_a 9,372,2^-10ohm
Ra Table,R_a3,Cell3 R_a 10,540,2^-10ohm
Ra Table,R_a3,Cell3 R_a 11,616,2^-10ohm
Ra Table,R_a3,Cell3 R_a 12,887,2^-10ohm
Ra Table,R_a3,Cell3 R_a 13,1709,2^-10ohm
Ra Table,R_a3,Cell3 R_a 14,8217,2^-10ohm
Ra Table,R_a0x,xCell0 R_a flag,ffff,-
Ra Table,R_a0x,xCell0 R_a 0,299,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 1,78,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 2,92,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 3,138,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 4,77,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 5,98,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 6,84,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 7,138,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 8,322,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 9,372,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 10,540,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 11,616,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 12,887,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 13,1709,2^-10ohm
Ra Table,R_a0x,xCell0 R_a 14,8217,2^-10ohm
Ra Table,R_a1x,xCell1 R_a flag,ffff,-
Ra Table,R_a1x,xCell1 R_a 0,299,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 1,78,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 2,92,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 3,138,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 4,77,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 5,98,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 6,84,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 7,138,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 8,322,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 9,372,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 10,540,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 11,616,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 12,887,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 13,1709,2^-10ohm
Ra Table,R_a1x,xCell1 R_a 14,8217,2^-10ohm
Ra Table,R_a2x,xCell2 R_a flag,ffff,-
Ra Table,R_a2x,xCell2 R_a 0,299,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 1,78,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 2,92,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 3,138,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 4,77,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 5,98,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 6,84,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 7,138,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 8,322,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 9,372,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 10,540,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 11,616,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 12,887,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 13,1709,2^-10ohm
Ra Table,R_a2x,xCell2 R_a 14,8217,2^-10ohm
Ra Table,R_a3x,xCell3 R_a flag,ffff,-
Ra Table,R_a3x,xCell3 R_a 0,299,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 1,78,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 2,92,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 3,138,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 4,77,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 5,98,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 6,84,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 7,138,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 8,322,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 9,372,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 10,540,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 11,616,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 12,887,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 13,1709,2^-10ohm
Ra Table,R_a3x,xCell3 R_a 14,8217,2^-10ohm
Tue Apr 26 10:50:07 CEST 2016
Device Name = bq40z60
Firmware Version = V0_13_BLD0019
Design Capacity = 4400
Design Voltage = 10800
Specification Info = 0x0031
Manufacturer Date = 1980-1-1
Serial Number = 0x0001
Manufacturer Name = Texas Instruments
Device Chemistry = LION
Sample,DateTime,ElapsedTime,BattMode,Voltage,Current,AvgCurr,ChgCurr,ChgVolt,BattStat,OpStatA,OpStatB,TempRange,ChgStat,ChgrStat,GaugeStat,ITStat,MfgStat,SafetyAlertAB,SafetyStatAB,SafetyAlertCD,SafetyStatCD,PFAlertAB,PFStatAB,PFAlertCD,PFStatCD,Vacp,CellCurr1,CellCurr2,CellCurr3,CellCurr4,CellTemp,LStatus,ChgCurrReg,LogRowTime(ms),LogStatus
1,2016-04-26 10:50:07,0.252,0x6081,11046,-44,-44,1000,12300,0x00C0,0x01C7,0x0000,0x08,0x0004,0x0000,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,6,-47,-47,-47,0,20.7,4,0,519,SUCCESS
2,2016-04-26 10:50:08,0.802,0x6081,11046,-44,-44,1000,12300,0x00C0,0x01C7,0x0000,0x08,0x0004,0x0000,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,5,-47,-47,-47,0,20.7,4,0,501,SUCCESS
3,2016-04-26 10:50:08,1.323,0x6081,11046,-44,-44,1000,12300,0x00C0,0x01C7,0x0000,0x08,0x0004,0x0000,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,2,-48,-47,-48,0,20.7,4,0,512,SUCCESS
4,2016-04-26 10:50:09,2.146,0x6081,11046,-44,-44,1000,12300,0x00C0,0x01C7,0x0000,0x08,0x0004,0x0000,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,8,-47,-47,-47,0,20.7,4,0,516,SUCCESS
5,2016-04-26 10:50:09,2.677,0x6081,11046,-44,-44,1000,12300,0x00C0,0x01C7,0x0000,0x08,0x0004,0x0000,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,0,-48,-47,-47,0,20.7,4,0,531,SUCCESS
6,2016-04-26 10:50:10,3.233,0x6081,11046,-44,-44,1000,12300,0x00C0,0x01C7,0x0000,0x08,0x0004,0x0000,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,1,-48,-47,-47,0,20.7,4,0,506,SUCCESS
7,2016-04-26 10:50:10,3.753,0x6081,11046,-44,-44,1000,12300,0x00C0,0x01C7,0x0000,0x08,0x0004,0x0000,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,1,-48,-47,-47,0,20.6,4,0,531,SUCCESS
8,2016-04-26 10:50:11,4.302,0x6081,11046,-44,-44,1000,12300,0x00C0,0x01C7,0x0000,0x08,0x0004,0x0000,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,7,-47,-47,-48,0,20.7,4,0,528,SUCCESS
9,2016-04-26 10:50:12,4.852,0x6081,11046,-44,-44,1000,12300,0x00C0,0x01C7,0x0000,0x08,0x0004,0x0000,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,8,-47,-47,-47,0,20.7,4,0,524,SUCCESS
10,2016-04-26 10:50:12,5.397,0x6081,11046,-44,-44,1000,12300,0x00C0,0x01C7,0x0000,0x08,0x0004,0x0000,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,7,-46,-47,-47,0,20.7,4,0,526,SUCCESS
11,2016-04-26 10:50:13,6.231,0x6081,11045,-44,-44,1000,12300,0x00C0,0x0197,0x0000,0x08,0x0004,0x0001,0xC0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,14756,-47,-46,-46,0,20.7,4,0,502,SUCCESS
12,2016-04-26 10:50:13,6.753,0x6081,11045,-43,-44,1000,12300,0x00C0,0x0197,0x0000,0x08,0x0004,0x0001,0xD0,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,14327,1576,1701,1700,0,20.8,4,76,526,SUCCESS
13,2016-04-26 10:50:14,7.302,0x6081,11196,1874,867,1000,12300,0x00C0,0x0197,0x0000,0x08,0x0004,0x0001,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,14312,3210,3250,3251,0,22.5,4,76,523,SUCCESS
14,2016-04-26 10:50:15,7.838,0x6081,11249,3887,1068,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14306,3734,3746,3750,0,23.7,4,76,533,SUCCESS
15,2016-04-26 10:50:15,8.385,0x6081,11268,3984,1068,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14310,3938,3941,3941,0,24.0,4,76,532,SUCCESS
16,2016-04-26 10:50:16,8.930,0x6081,11275,3984,1261,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14312,3972,3970,3970,0,24.3,4,76,517,SUCCESS
17,2016-04-26 10:50:16,9.468,0x6081,11281,3985,1261,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14307,3982,3979,3979,0,24.6,4,76,525,SUCCESS
18,2016-04-26 10:50:17,10.282,0x6081,11284,3986,1442,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14309,3983,3982,3983,0,24.7,4,76,538,SUCCESS
19,2016-04-26 10:50:18,10.834,0x6081,11285,3985,1611,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14307,3983,3982,3984,0,24.9,4,76,532,SUCCESS
20,2016-04-26 10:50:18,11.387,0x6081,11288,3985,1611,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14307,3984,3982,3982,0,25.0,4,76,526,SUCCESS
21,2016-04-26 10:50:19,11.932,0x6081,11289,3985,1769,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14310,3983,3983,3983,0,25.1,4,76,543,SUCCESS
22,2016-04-26 10:50:19,12.497,0x6081,11291,3985,1769,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14308,3984,3981,3983,0,25.2,4,76,540,SUCCESS
23,2016-04-26 10:50:20,13.059,0x6081,11294,3985,1916,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14307,3985,3983,3983,0,25.2,4,76,555,SUCCESS
24,2016-04-26 10:50:20,13.630,0x6081,11294,3985,1916,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14306,3987,3983,3983,0,25.3,4,76,562,SUCCESS
25,2016-04-26 10:50:21,14.497,0x6081,11297,3986,2053,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14304,3985,3983,3983,0,25.5,4,76,567,SUCCESS
26,2016-04-26 10:50:22,15.086,0x6081,11298,3985,2182,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14306,3984,3983,3983,0,25.5,4,76,525,SUCCESS
27,2016-04-26 10:50:22,15.631,0x6081,11299,3985,2182,1000,12300,0x4080,0x4993,0x0000,0x08,0x0304,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,14727,2259,2258,2260,0,25.2,4,76,541,SUCCESS
28,2016-04-26 10:50:23,16.193,0x6081,11208,3072,2301,0,0,0x0080,0x4993,0x0000,0x08,0x0304,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,14745,730,727,727,0,24.9,4,76,541,SUCCESS
29,2016-04-26 10:50:23,16.758,0x6081,11102,89,2154,0,0,0x0080,0x4993,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14742,239,238,236,0,24.4,4,77,553,SUCCESS
30,2016-04-26 10:50:24,17.353,0x6081,11085,9,2154,0,0,0x0080,0x4993,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14744,46,51,47,0,24.1,4,77,535,SUCCESS
31,2016-04-26 10:50:25,18.192,0x6081,11078,9,2012,0,0,0x0080,0x4993,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14742,13,14,13,0,23.9,4,77,539,SUCCESS
32,2016-04-26 10:50:25,18.752,0x6081,11074,8,1879,1000,12300,0x0080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,14320,1756,1757,1755,0,23.8,4,77,525,SUCCESS
33,2016-04-26 10:50:26,19.299,0x6081,11224,1961,1879,1000,12300,0x0080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,14301,3304,3306,3304,0,24.8,4,76,523,SUCCESS
34,2016-04-26 10:50:27,19.844,0x6081,11275,3975,2018,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14307,3780,3779,3777,0,25.4,4,76,555,SUCCESS
35,2016-04-26 10:50:27,20.422,0x6081,11292,4012,2018,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14309,3946,3946,3945,0,25.7,4,76,538,SUCCESS
36,2016-04-26 10:50:28,20.973,0x6081,11298,3984,2149,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14310,3972,3971,3972,0,25.8,4,76,518,SUCCESS
37,2016-04-26 10:50:28,21.513,0x6081,11303,3985,2149,1000,12300,0x4080,0x0197,0x0000,0x08,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14304,3980,3980,3979,0,26.0,4,76,524,SUCCESS
38,2016-04-26 10:50:29,22.344,0x6081,11306,3985,2271,1000,12600,0x4080,0x0197,0x0000,0x10,0x0204,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14304,3984,3983,3981,0,26.2,4,76,520,SUCCESS
39,2016-04-26 10:50:30,22.877,0x6081,11307,3985,2384,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14310,3985,3984,3985,0,26.2,4,76,517,SUCCESS
40,2016-04-26 10:50:30,23.417,0x6081,11309,3985,2384,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14305,3984,3984,3984,0,26.3,4,76,524,SUCCESS
41,2016-04-26 10:50:31,23.959,0x6081,11310,3985,2491,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14307,3985,3982,3983,0,26.3,4,76,527,SUCCESS
42,2016-04-26 10:50:31,24.508,0x6081,11311,3985,2491,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14306,3984,3982,3982,0,26.4,4,76,509,SUCCESS
43,2016-04-26 10:50:32,25.039,0x6081,11313,3985,2590,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14307,3985,3983,3983,0,26.5,4,76,523,SUCCESS
44,2016-04-26 10:50:32,25.585,0x6081,11314,3986,2590,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14307,3984,3985,3983,0,26.5,4,76,523,SUCCESS
45,2016-04-26 10:50:33,26.412,0x6081,11316,3986,2683,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14306,3984,3986,3983,0,26.6,4,76,523,SUCCESS
46,2016-04-26 10:50:34,26.950,0x6081,11317,3986,2769,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14305,3985,3986,3983,0,26.7,4,76,531,SUCCESS
47,2016-04-26 10:50:34,27.501,0x6081,11318,3986,2769,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0080,0x0000,0x0000,0x0000,0x0000,14307,3984,3985,3984,0,26.7,4,76,510,SUCCESS
48,2016-04-26 10:50:35,28.026,0x6081,11225,3057,2850,0,0,0x0080,0x4993,0x0000,0x10,0x0304,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,14742,1282,1285,1282,0,26.2,4,76,548,SUCCESS
49,2016-04-26 10:50:35,28.590,0x6081,11138,1069,2850,0,0,0x0080,0x4993,0x0000,0x10,0x0304,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14742,413,417,413,0,25.4,4,77,530,SUCCESS
50,2016-04-26 10:50:36,29.151,0x6081,11110,7,2666,0,0,0x0080,0x4993,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14743,80,80,82,0,25.2,4,77,529,SUCCESS
51,2016-04-26 10:50:36,29.694,0x6081,11099,8,2666,0,0,0x0080,0x4993,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14741,30,28,31,0,25.1,4,77,520,SUCCESS
52,2016-04-26 10:50:37,30.522,0x6081,11092,9,2489,0,0,0x0080,0x4993,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,14743,9,8,12,0,24.9,4,77,549,SUCCESS
53,2016-04-26 10:50:38,31.084,0x6081,11187,949,2324,1000,12600,0x0080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,14301,2746,2745,2745,0,25.6,4,77,533,SUCCESS
54,2016-04-26 10:50:38,31.639,0x6081,11274,2964,2324,1000,12600,0x0080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14308,3781,3781,3778,0,26.3,4,76,540,SUCCESS
55,2016-04-26 10:50:39,32.198,0x6081,11304,4027,2434,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14308,3919,3917,3917,0,26.6,4,76,542,SUCCESS
56,2016-04-26 10:50:39,32.762,0x6081,11315,3987,2537,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14305,3964,3963,3963,0,26.8,4,76,539,SUCCESS
57,2016-04-26 10:50:40,33.315,0x6081,11319,3986,2537,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14309,3978,3977,3977,0,26.9,4,76,548,SUCCESS
58,2016-04-26 10:50:41,34.175,0x6081,11322,3986,2633,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14317,3985,3985,3983,0,27.0,4,76,546,SUCCESS
59,2016-04-26 10:50:41,34.742,0x6081,11328,3988,2723,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14307,3987,3984,3983,0,27.1,4,76,526,SUCCESS
60,2016-04-26 10:50:42,35.281,0x6081,11326,3987,2723,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14318,3984,3983,3983,0,27.2,4,76,531,SUCCESS
61,2016-04-26 10:50:43,35.825,0x6081,11326,3986,2807,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14315,3984,3984,3983,0,27.3,4,76,533,SUCCESS
62,2016-04-26 10:50:43,36.371,0x6081,11327,3985,2807,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14313,3984,3983,3984,0,27.3,4,76,519,SUCCESS
63,2016-04-26 10:50:44,36.907,0x6081,11328,3985,2885,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14318,3984,3984,3985,0,27.4,4,76,527,SUCCESS
64,2016-04-26 10:50:44,37.455,0x6081,11329,3985,2885,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14317,3985,3985,3986,0,27.4,4,76,526,SUCCESS
65,2016-04-26 10:50:45,38.284,0x6081,11331,3986,2958,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14323,3985,3982,3985,0,27.4,4,76,523,SUCCESS
66,2016-04-26 10:50:46,38.833,0x6081,11331,3985,3027,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14318,3984,3983,3985,0,27.5,4,76,521,SUCCESS
67,2016-04-26 10:50:46,39.377,0x6081,11333,3986,3027,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14319,3984,3984,3984,0,27.5,4,76,521,SUCCESS
68,2016-04-26 10:50:47,39.939,0x6081,11333,3986,3090,0,0,0x0080,0x4993,0x0000,0x10,0x0304,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,14743,1280,1281,1284,0,27.5,4,76,537,SUCCESS
69,2016-04-26 10:50:47,40.505,0x6081,11154,1090,3090,0,0,0x0080,0x4993,0x0000,0x10,0x0304,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,14738,415,416,417,0,26.6,4,77,517,SUCCESS
70,2016-04-26 10:50:48,41.037,0x6081,11125,9,2891,0,0,0x0080,0x4993,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14741,137,139,137,0,26.1,4,77,547,SUCCESS
71,2016-04-26 10:50:48,41.601,0x6081,11113,9,2891,0,0,0x0080,0x4993,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14742,47,50,47,0,25.9,4,77,529,SUCCESS
72,2016-04-26 10:50:49,42.450,0x6081,11108,9,2700,0,0,0x0080,0x4993,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14742,10,8,10,0,25.7,4,77,538,SUCCESS
73,2016-04-26 10:50:50,43.003,0x6081,11201,948,2521,1000,12600,0x0080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0000,0x0000,0x0000,0x0000,0x0000,14317,2746,2744,2746,0,26.3,4,77,531,SUCCESS
74,2016-04-26 10:50:50,43.554,0x6081,11288,2964,2521,1000,12600,0x0080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14311,3623,3622,3624,0,27.0,4,76,526,SUCCESS
75,2016-04-26 10:50:51,44.103,0x6081,11318,4027,2618,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14318,3867,3868,3868,0,27.4,4,76,554,SUCCESS
76,2016-04-26 10:50:51,44.690,0x6081,11326,4000,2709,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14320,3964,3963,3965,0,27.5,4,76,544,SUCCESS
77,2016-04-26 10:50:52,45.269,0x6081,11333,3986,2709,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14319,3977,3978,3977,0,27.6,4,76,525,SUCCESS
78,2016-04-26 10:50:53,46.096,0x6081,11335,3986,2793,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14319,3984,3984,3983,0,27.9,4,76,526,SUCCESS
79,2016-04-26 10:50:53,46.643,0x6081,11336,3986,2793,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14316,3986,3984,3985,0,27.9,4,76,526,SUCCESS
80,2016-04-26 10:50:54,47.194,0x6081,11337,3986,2873,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14319,3984,3984,3985,0,27.9,4,76,538,SUCCESS
81,2016-04-26 10:50:54,47.751,0x6081,11339,3987,2947,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14318,3983,3985,3984,0,27.9,4,76,541,SUCCESS
82,2016-04-26 10:50:55,48.305,0x6081,11340,3986,2947,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14320,3984,3983,3984,0,28.0,4,76,534,SUCCESS
83,2016-04-26 10:50:56,48.852,0x6081,11341,3985,3016,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14320,3985,3983,3984,0,28.1,4,76,564,SUCCESS
84,2016-04-26 10:50:56,49.429,0x6081,11342,3985,3016,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14317,3984,3983,3983,0,28.1,4,76,533,SUCCESS
85,2016-04-26 10:50:57,50.260,0x6081,11343,3986,3080,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14319,3984,3985,3984,0,28.1,4,76,560,SUCCESS
86,2016-04-26 10:50:58,50.834,0x6081,11344,3987,3140,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14317,3986,3986,3985,0,28.2,4,76,548,SUCCESS
87,2016-04-26 10:50:58,51.405,0x6081,11346,3987,3140,1000,12600,0x4080,0x0197,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,14314,3987,3986,3984,0,28.2,4,76,523,SUCCESS
88,2016-04-26 10:50:59,51.941,0x6081,11346,3987,3196,0,0,0x0080,0x4993,0x0000,0x10,0x0304,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0000,0x0080,0x0000,0x0000,0x0000,0x0000,14739,1283,1285,1282,0,27.7,4,76,533,SUCCESS
89,2016-04-26 10:50:59,52.503,0x6081,11166,1080,3196,0,0,0x0080,0x4993,0x0000,0x10,0x0304,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14736,415,416,415,0,27.2,4,77,548,SUCCESS
90,2016-04-26 10:51:00,53.071,0x6081,11137,8,2990,0,0,0x0080,0x4993,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14739,137,137,140,0,26.7,4,77,557,SUCCESS
91,2016-04-26 10:51:00,53.644,0x6081,11126,8,2990,0,0,0x0080,0x4993,0x0000,0x10,0x0004,0x0003,0x90,0x0014,0x0618,0x0000,0x0000,0x0020,0x0080,0x0000,0x0000,0x0000,0x0000,14739,30,31,29,0,26.6,4,77,545,SUCCESS
