Tool/software: Linux
In my design we are using Battery of 10000mAh.
I wish to change the Battery charge\Discharge parameters as accordingly.
But i am getting following values When read the registers:
Voltage – 4211
Nominal available capacity – 1138
Full available capacity – 1138
Remain capacity – 1100
Full charge capacity – 1100
Average power – 1200
Register settings :
Unsealed – 00 00 80
cfgupdate – 00 13 00
block_data_control – 61 00
data_block_class – 3E 52
data_block 3f 00
block_data_check-sum – 60
design_capacity_loc - 4a
soft_reset – 00 42 00
seal_data – 00 20 00
Am setting design capacity is 0x2710 (10000mAh) as per data sheet , am trying to reading nominal available capacity but getting 1138 value. so my question is design capacity values and Nominal available capacity are not equal and any conversion is required to make it equal?
Naveen
