Other Parts Discussed in Thread: BQSTUDIO, EV2400
I am using the BQ34110EVM with an EV2400 and bqStudio to gauge a PbA battery. I am trying to execute an EOS Learning Phase (a manual Charge-before-discharge), so I give the EOS_EN command, followed by the EOS_START_LEARN command. The [LCMD] and [LCHG] bits in the EOS Learn Status register both set indicating the device is ready for a user controlled charge; however, I keep getting the Unexpected Current Detected error ([LUCD] and [LFAULT]). Of course the Learning Phase is then aborted automatically. The datasheet says this bit will set during the charge phase if a discharge current above a certain threshold is detected, but the current readings are all indicating a valid charging current. Can anyone tell me why I keep getting his error?
Thanks.
Mark
