Can someone confirm that the below are the same (in that I can read and write as desired) and that their values have no effect on the operation of the IC?
- 0x4040, Manufacturer Info A Length
- 0x4041-0x4060, Manufacturer Info Block A01-A32
- 0x4062-0x4065, Manufacturer Info Block B01-B04
Also, the subclass for #1 and #2 above is "Manufacturer Data" whereas that for #3 is "Manufacturer Info B". Is there a difference?
I am referring to Table 14-1 in the bq40z50-r1 Technical Reference, SLUUBC1C, http://www.ti.com/lit/pdf/sluubc1
Kwun
