Can someone please help explain to me how to set up the temperature sensors? I'm not sure if I can cut the sensors up into several pieces to measure different battery cells. Also, how is it mounted with the battery? I looked at the SLUU335A Manual and it shows a diagram of the sensor in between the batteries. Is this the best way to set it up? Can someone please send me screen shots or just explain how the temperature sensors are set up with the battery cells.
Thank you so much,
Brian
