Fusion digital power designer gives errors on SMBAlert mask with the UCD9248E version.
Other Parts Discussed in Thread: UCD9248, UCD9248E
I've switched from the UCD9248 to the UCD9248E version.
The difference is that in Fusion digital power designer a new tab appears. This is the "SMBAlert # Mask" tab under the configuration menu.
This is giving errors because it can't read the parameters from the UCD9248E. See screenshot:
I was not using this function, but because of this I can't use the "Calibrate device ..." function under the Tools menu, See attached error log:
error_calibrate_device.txt
Overview
Application: Fusion Digital Power Designer 2.0.40.0
Operating System: Microsoft Windows NT 5.1.2600 Service Pack 3
.NET Runtime: 4.0.30319.1022
Memory Used: 128.00 MB
Exception
TIDP.PMBus.n: SMBALERT_MASK_CML [Rail #1] read on UCD9248E @ Address 100d error: USB ADAPTER FIRMWARE DOES NOT SUPPORT PROCESS CALL TRANSACTIONS USED BY THIS COMMAND; CONTACT TI
   at TIDP.PMBus.Commands.ReadOnlyParameter`5.abf(Boolean A_0)
   at TIDP.PMBus.Commands.ReadOnlyParameter`5.ex()
   at TIDP.PMBus.Commands.ReadOnlyParameter`5.sx()
   at TIDP.PMBus.Commands.ReadWriteParameter`5.sx()
   at TIDP.PMBus.Commands.ReadOnlyParameter`5.get_Latest()
   at TIDP.PMBus.Commands.ReadOnlyParameter`5.d6()
   at TIDP.Factory.TaskLibrary.Fusion.a.nw()
   at TIDP.Factory.TaskLibrary.Fusion.a.n2()
   at TIDP.Factory.TaskLibrary.Fusion.a.n1(Object A_0, EventArgs A_1)
   at TIDP.Factory.Core.v.b()
   at TIDP.Factory.Core.v.a(a A_0)
   at TIDP.Factory.Core.v.b(a A_0)
   at TIDP.Factory.TaskLibrary.Fusion.a.nv(Object A_0, EventArgs A_1)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at DevExpress.XtraEditors.BaseButton.OnClick(EventArgs e)
   at DevExpress.XtraEditors.BaseButton.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at DevExpress.Utils.Controls.ControlBase.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Loaded Assemblies
0f0ajf1v
   Version: 2.0.7.35489
   Info Version:
<empty>
   Location: file:///C:/WINNT/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
   Public Key Token:
0zwtvtqb
   Info Version:
<empty>
   Public Key Token:
43oshf3j
   Version: 1.9.63.35518
   Info Version:
<empty>
   Public Key Token:
505jgj2i
   Info Version:
<empty>
   Public Key Token:
bhcqezuk
   Info Version:
<empty>
   Public Key Token:
ce2loqos
   Info Version:
<empty>
   Public Key Token:
Com.Muegel.Misc
   Version: 2.0.7.27908
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/Com.Muegel.Misc.DLL
   Public Key Token:
Com.Muegel.WindowsApp.Win32API
   Version: 2.0.7.27924
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/Com.Muegel.WindowsApp.Win32API.DLL
   Public Key Token:
d5lqrw0c
   Version: 1.9.63.35527
   Info Version:
<empty>
   Public Key Token:
DevExpress.Data.v6.2
   Version: 6.2.10.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/DevExpress.Data.v6.2.DLL
   Public Key Token: 79868B8147B5EAE4
DevExpress.Utils.v6.2
   Version: 6.2.10.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/DevExpress.Utils.v6.2.DLL
DevExpress.XtraBars.v6.2
   Version: 6.2.10.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/DevExpress.XtraBars.v6.2.DLL
DevExpress.XtraEditors.v6.2
   Version: 6.2.10.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/DevExpress.XtraEditors.v6.2.DLL
DevExpress.XtraGrid.v6.2
   Version: 6.2.10.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/DevExpress.XtraGrid.v6.2.DLL
DevExpress.XtraLayout.v6.2
   Version: 6.2.10.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/DevExpress.XtraLayout.v6.2.DLL
DevExpress.XtraNavBar.v6.2
   Version: 6.2.10.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/DevExpress.XtraNavBar.v6.2.DLL
DevExpress.XtraPrinting.v6.2
   Version: 6.2.10.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/DevExpress.XtraPrinting.v6.2.DLL
DundasWinChart
   Version: 7.1.0.1810
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/DundasWinChart.DLL
   Public Key Token: A4C03DCE5DB22406
f3zlh55j
   Info Version:
<empty>
   Public Key Token:
Free.CommandLine
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/Free.CommandLine.DLL
   Public Key Token:
Free.Hid
   Version: 2.0.7.27925
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/Free.Hid.DLL
   Public Key Token:
Free.Misc
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/Free.Misc.DLL
   Public Key Token:
Free.WinForms.Misc
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/Free.WinForms.Misc.DLL
   Public Key Token:
fsl1btoo
   Info Version:
<empty>
   Public Key Token:
   Version: 2.0.40.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/Fusion Digital Power Designer.exe
   Public Key Token:
ga1aakxq
   Info Version:
<empty>
   Public Key Token:
hxw3r2bt
   Info Version:
<empty>
   Public Key Token:
ioiwv2s5
   Info Version:
<empty>
   Public Key Token:
mgjiqz1b
   Info Version:
<empty>
   Public Key Token:
Microsoft.mshtml
   Version: 7.0.3300.0
   Info Version:
<empty>
   Location: file:///C:/WINNT/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
   Public Key Token: B03F5F7F11D50A3A
Microsoft.VisualBasic
   Version: 10.0.0.0
   Info Version:
10.0.30319.1
   Location: file:///C:/WINNT/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
mscorlib
   Version: 4.0.0.0
   Info Version:
4.0.30319.1022
   Location: file:///C:/WINNT/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
   Public Key Token: B77A5C561934E089
plfum0cd
   Info Version:
<empty>
   Public Key Token:
qj2rhzec
   Info Version:
<empty>
   Public Key Token:
rncnuo2x
   Info Version:
<empty>
   Public Key Token:
System
   Version: 4.0.0.0
   Info Version:
4.0.30319.1001
System.Configuration
   Version: 4.0.0.0
   Info Version:
4.0.30319.1015
   Location: file:///C:/WINNT/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
   Version: 4.0.0.0
   Info Version:
4.0.30319.233
   Location: file:///C:/WINNT/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Data
   Version: 4.0.0.0
   Info Version:
4.0.30319.237
   Location: file:///C:/WINNT/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Drawing
   Version: 4.0.0.0
   Info Version:
4.0.30319.1001
   Location: file:///C:/WINNT/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Numerics
   Version: 4.0.0.0
   Info Version:
4.0.30319.1
   Location: file:///C:/WINNT/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Web
   Version: 4.0.0.0
   Info Version:
4.0.30319.1022
   Location: file:///C:/WINNT/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
   Version: 4.0.0.0
   Info Version:
4.0.30319.1002
   Location: file:///C:/WINNT/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Xml
   Version: 4.0.0.0
   Info Version:
4.0.30319.1015
   Location: file:///C:/WINNT/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
szmcrbaw
   Version: 2.0.7.35480
   Info Version:
<empty>
   Public Key Token:
TIDP.DevEx.Skin1
   Version: 1.0.0.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.DevEx.Skin1.DLL
   Public Key Token: 95FC6C5621878F0A
TIDP.Factory.Core.ManualOnly
   Version: 2.0.7.35508
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.Factory.Core.ManualOnly.DLL
   Public Key Token:
TIDP.Factory.NIStubForManualOnly
   Version: 1.9.63.19980
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.Factory.NIStubForManualOnly.DLL
   Public Key Token:
TIDP.Factory.TaskLibrary.Fusion.ManualOnly
   Version: 1.9.63.35516
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.Factory.TaskLibrary.Fusion.ManualOnly.DLL
   Public Key Token:
TIDP.Factory.TaskLibrary.ManualOnly
   Version: 2.0.7.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.Factory.TaskLibrary.ManualOnly.DLL
   Public Key Token:
TIDP.Misc
   Version: 2.0.7.35478
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.Misc.DLL
   Public Key Token:
TIDP.Net.ProxyPrefs
   Version: 1.4.0.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.Net.ProxyPrefs.DLL
   Public Key Token:
TIDP.PMBus
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.PMBus.DLL
   Public Key Token:
TIDP.PMBus.Design.TimeModel
   Version: 2.0.7.35479
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.PMBus.Design.TimeModel.DLL
   Public Key Token:
TIDP.PMBus.DeviceGUI.UCD3000
   Version: 1.9.63.35515
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.PMBus.DeviceGUI.UCD3000.DLL
   Public Key Token:
TIDP.PMBus.ParameterControls
   Version: 2.0.7.35509
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.PMBus.ParameterControls.DLL
   Public Key Token:
TIDP.PMBus.WinForms
   Version: 2.0.7.35512
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.PMBus.WinForms.DLL
   Public Key Token:
TIDP.SAA
   Version: 2.0.7.35481
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.SAA.DLL
   Public Key Token:
TIDP.SAA.WinForms.Misc
   Version: 2.0.7.35482
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.SAA.WinForms.Misc.DLL
   Public Key Token:
TIDP.WinForms.Apps.DPGUI
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.WinForms.Apps.DPGUI.DLL
   Public Key Token:
TIDP.WinForms.Apps.DPGUI.DPGUI1
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.WinForms.Apps.DPGUI.DPGUI1.DLL
   Public Key Token:
TIDP.WinForms.Apps.DPGUI.HelpCenter
   Version: 1.9.63.35482
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.WinForms.Apps.DPGUI.HelpCenter.DLL
   Public Key Token:
TIDP.WinForms.Dundas
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.WinForms.Dundas.DLL
   Public Key Token:
TIDP.WinForms.Misc
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.WinForms.Misc.DLL
   Public Key Token:
TIDP.WinForms.Util
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/TIDP.WinForms.Util.DLL
   Public Key Token:
ujmw5ykr
   Info Version:
<empty>
   Public Key Token:
uogr03jn
   Info Version:
<empty>
   Public Key Token:
xdfsoe4a
   Info Version:
<empty>
   Public Key Token:
xjk4rajo
   Info Version:
<empty>
   Public Key Token:
xpa30yah
   Info Version:
<empty>
   Public Key Token:
XtraDataTempAssembly
   Version: 0.0.0.0
   Info Version:
<empty>
   Location: file:///C:/Program Files/Texas Instruments Fusion Digital Power Designer/bin/DevExpress.Data.v6.2.dll
   Public Key Token:
y4kx0n1w
   Info Version:
<empty>
   Public Key Token:
Also is this giving warnings when saving the project file:
Looking at the first screenshot the error is:
“USB ADAPTER FIRMWARE DOES NOT SUPPORT PROCESS CALL TRANSACTIONS USED BY THIS COMMAND;CONTACT TI”
I've checked the firmware of the USB adapter, but I'm using the latest version. See screenshot:
What can I do to solve this error?
Kind regards,
Ben
  • Ben,
    Please use firmware version 1.0.11 instead of 1.0.14. Version 1.0.14 supports "Block Process Call" which needed for SMBALERT MASK commands; version 1.0.14 does not support "Block Process Call" but add support for "Parallel Mode". We will put more firmware description in the GUI so that users can choose the correct one.
    Thanks for your post.
  • A bit strange the firmware of the USB adapter is not backwards compatible, so that you can't use the latest version, but it worked fine! Thanks!
