Dear all,
I need to use a bi-directional hall effect sensor for current measurement in my application. The output of the current measurement block will be input for EADC which has 1.6V maximum range. All the products that I found has a Vdd/2 (Vdd is mostly found as 5V) offset voltage and therefore, I am not able to use this offset voltage in EADC. Is there any hall effect sensor which has a variable offset, that you may suggest for UCD3138.
Thanks in advanced
Merih
