Part Number: FUSION_DIGITAL_POWER_DESIGNER
I am trying to import a system file into my device (TPS53622) using the Fusion Digital Power Designer. For some reason, when I import the file with the device connected, all of the settings match the system file except Iout OC Warn Limit and Iout OC Fault Limit. However, when I import the file in offline mode, all of the settings including the Iout OC Warn Limit and Iout OC Fault Limit are there. Am I missing a parameter when I export the system file?
Eric Fu
