HSFB code has IDE ,I want to use the IDE fuction .
I need to “# define IDE_ENABLE ” ,Is there anything else that needs to be set or noticed?
THX.
#ifdef IDE_ENABLE //from HSFB code
init_ide();
#endif
THX.
init_ide();
#endif
Yes. Just define IDE_ENABLE and IDE will be added.
Please note that the part that you are showing (init_ide();) is not the only part that will be activated if you add the IDE_ENABLE definition.
The other part is inside the file "standard_interrupt.c". This part is tuned toward TI's EVM and need to be modified to fit other hardware.
