• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Digital Power » Digital Power Forum » How does the Fusion Digital Power Designer GUI associate a project file when connecting to a previously configured Digital Controller (UCD92xx)?
Share
Digital Power
  • Forum
  • Files
Options
  • Subscribe via RSS
This question is answered
Mark Pieper
Posted by Mark Pieper
on Oct 05 2010 08:46 AM
Intellectual2380 points
When the GUI is started while connected to a board that is the same configuration as the previous board that was tested, it appears to load a project file containing all of the design related information. How does the GUI decide which project file to load for a given board?
Fusion GUI UCD924x
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Michael Muegel
    Posted by Michael Muegel
    on Oct 05 2010 10:06 AM
    Verified Answer
    Verified by Brad
    Prodigy180 points
    This may be non intuitive, but Fusion Digital Power Designer is not loading a project file in online mode. It is loading its own mini-project for each unique part/address pair it has worked with (for example, a UCD9240 @ address 126). This mini-project data -– design tool data such as your circuit design and compensation settings and sequencing simulation prefs -– are stored in the user’s prefs database. This is the file C:\Program Files\Texas Instruments Fusion Digital Power Designer\data\prefs.xml if you are curious.
    Say you do this:
    • Connect to device in online mode
    • Jump to the design task
    • Notice there is no design, so you import a project file
    • This loads design data from the project file into the design tool. You see your power stage circuit and comensation inputs.
    • Tweak the design
    • Write out your change to the device
    • Quit GUI
    YOUR ORIGINAL PROJECT FILE WAS NOT UPDATED IN THIS CASE. The GUI saved your design data to the global prefs file, and tied it to the device you were working with (UCD9240 @ 126 in this example).
    If you later start the GUI again, it loads the device config from “live” device and uses the cached design for the part/address it saved above. This is not in a project file, just user prefs.
    So you need to save out your changes in online mode to your project file to ensure you can move these to other PCs, work with them offline, etc. You don't necissarily need to do this every time you quit the GUI, but if you have made changes to the design tool and are happy with your changes, I'd recommend saving these changes to a project file for future use in offline mode, archival purposes, etc.
     -Mike
    Report Abuse
    • Reply
  • Marc Hanshaw
    Posted by Marc Hanshaw
    on Jul 30 2012 14:12 PM
    Prodigy20 points
    I have an issue with Fusion. I changed two channels on line. I made sure they worked in hardware. Then I tried to save the project. I then turn off the power supply and power it back up. Fusion connects but instead of the change d channels I am getting the old configuration with the channels swapped. Also it keeps changing my Vin variable for scale bacjk to 0.250 V every time.
    Report Abuse
    • Reply
  • Richard Marsh
    Posted by Richard Marsh
    on Jul 31 2012 08:22 AM
    Intellectual730 points
    I had this problem.  You need to make sure you save your changes to the flash in the controller.  Make sure "Write to Hardware" has been done. Then click "Store RAM to Flash" to save it in the device.
    Richard
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
