Other Parts Discussed in Thread: UCD3138
Use the function of pmbus_handler() in the main loop. Then use the i2c tool for read the output voltage. if the module with high load, SCL will be set low in 35ms. why the scl set low? i have change some i2c tools for the command and it also have the same appearance.
