Hello, We are using UCD3138 for an active clamp forward converter with synchronous rectifications on the secondary. Below is the configuration for the DPWMs. Can someone verify the DPWMs below?
DPWM0A = Primary_Forward_MOSFET
DPWM0B = Secondary_Clamp_MOSFET
DPWM1A= Primary_Clamp_MOSFET
DPWM1B = Secondary_Forward_MOSFET
void init_dpwm0_OL(void) // DPWM1B is Used to drive Sync-FET
Dpwm0Regs.DPWMCTRL1.bit.GLOBAL_PERIOD_EN = 1;
Dpwm0Regs.DPWMEV1.all = 0; //
Dpwm0Regs.DPWMEV2.all = (PERIOD >> 1);
Dpwm0Regs.DPWMEV3.all = (PERIOD >> 1 ) + DEAD_TIME;
Dpwm0Regs.DPWMEV4.all = PERIOD - DEAD_TIME;
Dpwm0Regs.DPWMCTRL0.bit.PWM_MODE = 0; // Set to normal mode
Dpwm0Regs.DPWMCTRL0.bit.CLA_EN = 1;
Dpwm0Regs.DPWMCTRL1.bit.EVENT_UP_SEL = 1; // Events update at the end of period
Dpwm0Regs.DPWMCTRL1.bit.CHECK_OVERRIDE = 1; // Normally CLA == 0 is considered a fault; Set the check-override so cla==0 is
Dpwm0Regs.DPWMCTRL1.bit.ALL_PHASE_CLK_ENA = 1; // Need all phases for hi Resolution
Dpwm0Regs.DPWMSAMPTRIG1.all = 1500; //(PERIOD >> 1); //2100; 279*16ns = 4.464us;-5000; // Writing to all in order to normalize to high resolution
Dpwm0Regs.DPWMCTRL2.bit.SAMPLE_TRIG_1_EN = 1;
Dpwm0Regs.DPWMCTRL0.bit.PWM_EN = 1;
Dpwm0Regs.DPWMCTRL0.bit.MSYNC_SLAVE_EN =0; // DPWm0 is master
Dpwm0Regs.DPWMCTRL0.bit.MASTER_SYNC_CNTL_SEL =0; // DPWm0 is master
//Enable Sync Fets
Dpwm0Regs.DPWMCTRL2.bit.IDE_DUTY_B_EN = 1; //enable ide
void init_dpwm1_OL(void) // DPWM1B is Used to drive Sync-FET
Dpwm1Regs.DPWMCTRL0.bit.PWM_EN = 0; //disable locally for init
Dpwm1Regs.DPWMCTRL0.bit.CLA_EN = 1; //default is 1 - use cla
Dpwm1Regs.DPWMPRD.all = PERIOD; // use .all for all values, so that the scaling matches
Dpwm1Regs.DPWMEV4.all = 0; // set EVENT 1 to 0% (start) of period
Dpwm1Regs.DPWMEV3.all = (PERIOD >> 1); // set EVENT 2 to 25% of period
Dpwm1Regs.DPWMEV2.all = (PERIOD >> 1) + DEAD_TIME; // set EVENT 3 to 50% of period
Dpwm1Regs.DPWMEV1.all = PERIOD - DEAD_TIME; // set EVENT 4 to 75% of period
Dpwm1Regs.DPWMCTRL0.bit.D_ENABLE = 1; //Duty Cycle is 1-D
Dpwm1Regs.DPWMCYCADJA.all = DEAD_TIME*2;
Dpwm1Regs.DPWMSAMPTRIG1.all = (PERIOD)/2; //3/4 of period
Dpwm1Regs.DPWMCTRL2.bit.SAMPLE_TRIG_1_EN = 1; //enable 1 sample trigger
Dpwm1Regs.DPWMCTRL1.bit.EVENT_UP_SEL = 1; //update at end of period
Dpwm1Regs.DPWMCTRL0.bit.PWM_MODE = 4; //normal mode (this is NOT the default)
Dpwm1Regs.DPWMCTRL0.bit.PWM_EN = 1; // enable DPWM0 locally
LoopMuxRegs.DPWMMUX.bit.DPWM1_SYNC_SEL = 0;
Dpwm1Regs.DPWMCTRL0.bit.MSYNC_SLAVE_EN = 1; // DPWm0 is master, DPWM1 is slave
//Enable Sync Fets
Dpwm1Regs.DPWMCTRL2.bit.IDE_DUTY_B_EN = 1; //enable ide
