I have a requirement to generate the square wave with output voltage ranges from 5Vdc to 30Vdc. I like to use variable supply of this range and switch the voltage with single buffer to generate square wave form. The output requires to drive 20-30mA load. Is there any supply having variable output voltage available? Suggest if any idea suites this application.
