What is the tolerance over temperature and manufacturing of the 200k pull-up resistor on the "IN-" pin of the UCC27511DBV?
The tolerance of pull up and pull down resistors on the driver inputs are generally not precision devices. The recent driver I inquired with IC design had pulldown/pullup resistance tolerance that will vary <+/-40%. If this is expected to be any issue in this application, respond and I can inquire about this particular driver.
