Please use the user guide for each board separately (before trying to operate them together) and go step by step from Software Build 1 through 3 to understand the software and operation of each board.
Since you are having problem connecting to the board with CCS you have to go through the steps described in the user-guide (see UG_HV_SOLAR_DC_DC_Rev1.pdf, pages 13~14). Pls change the jumper setting (as mentioned in the UG) to allow code execution from RAM. You may need to see the control card documentation available in ControlSUITE. UG_SOLAR_Micro_Inverter.pdfCheck the Target Configuration before trying to connecting to the target. This is standard procedure for all of our kits. Attached is an example where this is detailed on Page 23 (Software setup). Although this doc is for another design, but this step related to Target Configuration also applies to these solar boards. If you still cannot connect to the board after following these steps then I would say you have some h/w issue. You will need to return the board and get a new one.
Shamim
Shamin,
We require assistance with our HV_SOLAR_DC_AC board. Out of the box, the GUI program will not communicate with the controller.
We expect a certain level of customer support for this product we have purchased. Please advise.
