Other Parts Discussed in Thread: BQ24192, BQEVSW, BQSTUDIO, GPCRA0
I am having difficulty getting the update status to change from 0 to 1 during a learning cycle. I have previously done a successful learning cycle but we have changed cell brand/model to Panasonic NCR18650B (1S4P). The new pack has a design capacity of 12000mAh (previously 8800mAh). Except for the change in battery, all other hardware is unchanged.
The steps I have followed are:-
- Reprogram firmware (3.29) to clear any hidden flags (as the gauge has previously been programmed and sealed in production).
- Load the new chemistry 2030 (one of several recommended during a chemistry analysis with <2% max error).
- Write configuration settings (modified from the previous values for the new chemistry and design capacity) - file attached. AX18 Pre-Learn.gg.csv.txt
* Texas Instruments Data Flash File * File created Mon May 08 12:24:02 2017 * * Device Number 520 * Firmware Version 3.29 * Build Number not available * Order Number not available * * bqz Device Number 0x0520 * bqz Firmware Version 0x0329 * bqz Build Number 3.29 * * Field Order: Class name, Subclass name, Parameter name, Parameter Value,Display Units Configuration,Safety,OT Chg,55.0,°C Configuration,Safety,OT Chg Time,2,s Configuration,Safety,OT Chg Recovery,50.0,°C Configuration,Safety,OT Dsg,60.0,°C Configuration,Safety,OT Dsg Time,2,s Configuration,Safety,OT Dsg Recovery,55.0,°C Configuration,Charge Inhibit Cfg,Chg Inhibit Temp Low,0,°C Configuration,Charge Inhibit Cfg,Chg Inhibit Temp High,45.0,°C Configuration,Charge Inhibit Cfg,Temp Hys,5.0,°C Configuration,Charge,Charging Voltage,4200,mV Configuration,Charge,Delta Temp,5.0,°C Configuration,Charge,Suspend Low Temp,-5.0,°C Configuration,Charge,Suspend High Temp,55.0,°C Configuration,Charge Termination,Taper Current,384,mA Configuration,Charge Termination,Taper Voltage,100,mV Configuration,Charge Termination,TCA Set %,99,% Configuration,Charge Termination,TCA Clear %,95,% Configuration,Charge Termination,FC Set %,-1,% Configuration,Charge Termination,FC Clear %,98,% Configuration,Charge Termination,DODatEOC Delta T,5.0,°C Configuration,Data,Initial Standby,-10,mA Configuration,Data,CC Threshold,10800,mAh Configuration,Data,Design Capacity,12000,mAh Configuration,Data,Des Energy Scale,10,Num Configuration,Data,SOH LoadI,-400,mA Configuration,Data,Default Temperature,298.2,°K Configuration,Data,Device Name,bq27520,String Configuration,Data,Data Flash Version,0003,Hex Configuration,Discharge,SOC1 Set Threshold,600,mAh Configuration,Discharge,SOC1 Clear Threshold,720,mAh Configuration,Discharge,SysDown Set Volt Threshold,3150,mV Configuration,Discharge,SysDown Set Volt Time,2,s Configuration,Discharge,SysDown Clear Volt,3400,mV Configuration,Discharge,Final Voltage,3100,mV Configuration,Discharge,Final Volt Time,2,s Configuration,Discharge,Def Avg I Last Run,-10,mA Configuration,Discharge,Def Avg P Last Run,-40,mW Configuration,Registers,Op Config,0973,Flag Configuration,Registers,SOC Delta,1,% Configuration,Registers,i2c Timeout,4,0.5s Configuration,Registers,DF Wr Ind Wait,0,100us Configuration,Registers,OpConfig B,4a,Flag Configuration,Registers,OpConfig C,2c,Flag Configuration,Registers,OpConfig D,5e,Flag Configuration,Registers,OpConfig E,00,Flag Configuration,Power,Flash Update OK Voltage,2800,mV Configuration,Power,Sleep Current,10,mA Configuration,Power,Hibernate I,8,mA Configuration,Power,Hibernate V,2550,mV System Data,Manufacturer Info,Block 0,00,Hex System Data,Manufacturer Info,Block 1,00,Hex System Data,Manufacturer Info,Block 2,00,Hex System Data,Manufacturer Info,Block 3,00,Hex System Data,Manufacturer Info,Block 4,00,Hex System Data,Manufacturer Info,Block 5,00,Hex System Data,Manufacturer Info,Block 6,00,Hex System Data,Manufacturer Info,Block 7,00,Hex System Data,Manufacturer Info,Block 8,00,Hex System Data,Manufacturer Info,Block 9,00,Hex System Data,Manufacturer Info,Block 10,00,Hex System Data,Manufacturer Info,Block 11,00,Hex System Data,Manufacturer Info,Block 12,00,Hex System Data,Manufacturer Info,Block 13,00,Hex System Data,Manufacturer Info,Block 14,00,Hex System Data,Manufacturer Info,Block 15,00,Hex System Data,Manufacturer Info,Block 16,00,Hex System Data,Manufacturer Info,Block 17,00,Hex System Data,Manufacturer Info,Block 18,00,Hex System Data,Manufacturer Info,Block 19,00,Hex System Data,Manufacturer Info,Block 20,00,Hex System Data,Manufacturer Info,Block 21,00,Hex System Data,Manufacturer Info,Block 22,00,Hex System Data,Manufacturer Info,Block 23,00,Hex System Data,Manufacturer Info,Block 24,00,Hex System Data,Manufacturer Info,Block 25,00,Hex System Data,Manufacturer Info,Block 26,00,Hex System Data,Manufacturer Info,Block 27,00,Hex System Data,Manufacturer Info,Block 28,00,Hex System Data,Manufacturer Info,Block 29,00,Hex System Data,Manufacturer Info,Block 30,00,Hex System Data,Manufacturer Info,Block 31,00,Hex Gas Gauging,IT Cfg,Load Select,1,Num Gas Gauging,IT Cfg,Load Mode,0,Num Gas Gauging,IT Cfg,Max Res Factor,15,Num Gas Gauging,IT Cfg,Min Res Factor,7,Num Gas Gauging,IT Cfg,Ra Filter,800,Num Gas Gauging,IT Cfg,Fast Qmax Start DOD %,92,% Gas Gauging,IT Cfg,Fast Qmax End DOD %,96,% Gas Gauging,IT Cfg,Fast Qm Start V Delta,125,mV Gas Gauging,IT Cfg,Fast Qmax Current Threshold,4,Hr rate Gas Gauging,IT Cfg,Fast Qmax Min Points,3,Num Gas Gauging,IT Cfg,Min % Passed Chg for Qm,37,% Gas Gauging,IT Cfg,Qmax Filter,96,Num Gas Gauging,IT Cfg,Max % Default Qmax,110,% Gas Gauging,IT Cfg,Terminate Voltage,3300,mV Gas Gauging,IT Cfg,Term V Delta,200,mV Gas Gauging,IT Cfg,ResRelax Time,500,s Gas Gauging,IT Cfg,User Rate-mA,0,mA Gas Gauging,IT Cfg,User Rate-m/cW,0,pwr Gas Gauging,IT Cfg,Reserve Cap-mAh,600,mAh Gas Gauging,IT Cfg,Reserve Cap-m/cWh,222,pwr Gas Gauging,IT Cfg,Min Delta Voltage,0,mV Gas Gauging,IT Cfg,Max Sim Rate,1,Hr rate Gas Gauging,IT Cfg,Min Sim Rate,20,Hr rate Gas Gauging,IT Cfg,Ra Max Delta,44,mOhm Gas Gauging,IT Cfg,Qmax Max Delta %,5,% Gas Gauging,IT Cfg,DeltaV Max dV,10,mV Gas Gauging,IT Cfg,Max Res Scale,5000,Num Gas Gauging,IT Cfg,Min Res Scale,200,Num Gas Gauging,IT Cfg,Fast Scale Start SOC,10,% Gas Gauging,Current Thresholds,Dsg Current Threshold,60,mA Gas Gauging,Current Thresholds,Chg Current Threshold,75,mA Gas Gauging,Current Thresholds,Quit Current,40,mA Gas Gauging,Current Thresholds,Dsg Relax Time,60,s Gas Gauging,Current Thresholds,Chg Relax Time,60,s Gas Gauging,Current Thresholds,Quit Relax Time,1,s Gas Gauging,Current Thresholds,Transient Factor Charge,128,Num Gas Gauging,Current Thresholds,Transient Factor Discharge,128,Num Gas Gauging,Current Thresholds,Max IR Correct,400,mV Gas Gauging,State,IT Enable,00,Hex Gas Gauging,State,App Status,00,Flag Gas Gauging,State,Qmax Cell 0,1000,mAh Gas Gauging,State,Cycle Count 0,0,Num Gas Gauging,State,Update Status 0,00,Hex Gas Gauging,State,Qmax Cell 1,1000,mAh Gas Gauging,State,Cycle Count 1,0,Num Gas Gauging,State,Update Status 1,00,Hex Gas Gauging,State,Avg I Last Run,-10,mA Gas Gauging,State,Avg P Last Run,-4,pwr Gas Gauging,State,Delta Voltage,2,mV Gas Gauging,State,T Rise,2,Num Gas Gauging,State,T Time Constant,1000,Num Gas Gauging,State,Cell 0 V at Chg Term,4200,mV Gas Gauging,State,Cell 1 V at Chg Term,4200,mV OCV Tables,OCVa0 Table,Chem ID,2030,Flag OCV Tables,OCVa0 Table,Qmax Cell,1000,mAh OCV Tables,OCVa0 Table,Update Status,00,Hex OCV Tables,OCVa1 Table,Chem ID,2030,Flag OCV Tables,OCVa1 Table,Qmax Cell,1000,mAh OCV Tables,OCVa1 Table,Update Status,00,Hex Ra Tables,Ra0 Default,Ra Status,ff,Hex Ra Tables,Ra0 Default,Ra Flag,55,Hex Ra Tables,Ra0 Default,Ra Base,16,Num Ra Tables,Ra0 Default,Ra Gain,0,Num Ra Tables,Ra0 Default,Ra 1,1,Num Ra Tables,Ra0 Default,Ra 2,4,Num Ra Tables,Ra0 Default,Ra 3,8,Num Ra Tables,Ra0 Default,Ra 4,-8,Num Ra Tables,Ra0 Default,Ra 5,-1,Num Ra Tables,Ra0 Default,Ra 6,2,Num Ra Tables,Ra0 Default,Ra 7,-5,Num Ra Tables,Ra0 Default,Ra 8,0,Num Ra Tables,Ra0 Default,Ra 9,1,Num Ra Tables,Ra0 Default,Ra 10,1,Num Ra Tables,Ra0 Default,Ra 11,6,Num Ra Tables,Ra0 Default,Ra 12,8,Num Ra Tables,Ra0 Default,Ra 13,21,Num Ra Tables,Ra0 Default,Ra 14,10,Num Ra Tables,Ra1 Default,Ra Status,ff,Hex Ra Tables,Ra1 Default,Ra Flag,55,Hex Ra Tables,Ra1 Default,Ra Base,16,Num Ra Tables,Ra1 Default,Ra Gain,0,Num Ra Tables,Ra1 Default,Ra 1,1,Num Ra Tables,Ra1 Default,Ra 2,4,Num Ra Tables,Ra1 Default,Ra 3,8,Num Ra Tables,Ra1 Default,Ra 4,-8,Num Ra Tables,Ra1 Default,Ra 5,-1,Num Ra Tables,Ra1 Default,Ra 6,2,Num Ra Tables,Ra1 Default,Ra 7,-5,Num Ra Tables,Ra1 Default,Ra 8,0,Num Ra Tables,Ra1 Default,Ra 9,1,Num Ra Tables,Ra1 Default,Ra 10,1,Num Ra Tables,Ra1 Default,Ra 11,6,Num Ra Tables,Ra1 Default,Ra 12,8,Num Ra Tables,Ra1 Default,Ra 13,21,Num Ra Tables,Ra1 Default,Ra 14,10,Num Ra Tables,Ra0 Table,Ra Status,ff,Hex Ra Tables,Ra0 Table,Ra Flag,55,Hex Ra Tables,Ra0 Table,Ra Base,16,Num Ra Tables,Ra0 Table,Ra Gain,0,Num Ra Tables,Ra0 Table,Ra 1,1,Num Ra Tables,Ra0 Table,Ra 2,4,Num Ra Tables,Ra0 Table,Ra 3,8,Num Ra Tables,Ra0 Table,Ra 4,-8,Num Ra Tables,Ra0 Table,Ra 5,-1,Num Ra Tables,Ra0 Table,Ra 6,2,Num Ra Tables,Ra0 Table,Ra 7,-5,Num Ra Tables,Ra0 Table,Ra 8,0,Num Ra Tables,Ra0 Table,Ra 9,1,Num Ra Tables,Ra0 Table,Ra 10,1,Num Ra Tables,Ra0 Table,Ra 11,6,Num Ra Tables,Ra0 Table,Ra 12,8,Num Ra Tables,Ra0 Table,Ra 13,21,Num Ra Tables,Ra0 Table,Ra 14,10,Num Ra Tables,Ra1 Table,Ra Status,ff,Hex Ra Tables,Ra1 Table,Ra Flag,55,Hex Ra Tables,Ra1 Table,Ra Base,16,Num Ra Tables,Ra1 Table,Ra Gain,0,Num Ra Tables,Ra1 Table,Ra 1,1,Num Ra Tables,Ra1 Table,Ra 2,4,Num Ra Tables,Ra1 Table,Ra 3,8,Num Ra Tables,Ra1 Table,Ra 4,-8,Num Ra Tables,Ra1 Table,Ra 5,-1,Num Ra Tables,Ra1 Table,Ra 6,2,Num Ra Tables,Ra1 Table,Ra 7,-5,Num Ra Tables,Ra1 Table,Ra 8,0,Num Ra Tables,Ra1 Table,Ra 9,1,Num Ra Tables,Ra1 Table,Ra 10,1,Num Ra Tables,Ra1 Table,Ra 11,6,Num Ra Tables,Ra1 Table,Ra 12,8,Num Ra Tables,Ra1 Table,Ra 13,21,Num Ra Tables,Ra1 Table,Ra 14,10,Num Ra Tables,Ra0x Table,Ra Status,ff,Hex Ra Tables,Ra0x Table,Ra Flag,ff,Hex Ra Tables,Ra0x Table,Ra Base,16,Num Ra Tables,Ra0x Table,Ra Gain,0,Num Ra Tables,Ra0x Table,Ra 1,1,Num Ra Tables,Ra0x Table,Ra 2,4,Num Ra Tables,Ra0x Table,Ra 3,8,Num Ra Tables,Ra0x Table,Ra 4,-8,Num Ra Tables,Ra0x Table,Ra 5,-1,Num Ra Tables,Ra0x Table,Ra 6,2,Num Ra Tables,Ra0x Table,Ra 7,-5,Num Ra Tables,Ra0x Table,Ra 8,0,Num Ra Tables,Ra0x Table,Ra 9,1,Num Ra Tables,Ra0x Table,Ra 10,1,Num Ra Tables,Ra0x Table,Ra 11,6,Num Ra Tables,Ra0x Table,Ra 12,8,Num Ra Tables,Ra0x Table,Ra 13,21,Num Ra Tables,Ra0x Table,Ra 14,10,Num Ra Tables,Ra1x Table,Ra Status,ff,Hex Ra Tables,Ra1x Table,Ra Flag,ff,Hex Ra Tables,Ra1x Table,Ra Base,16,Num Ra Tables,Ra1x Table,Ra Gain,0,Num Ra Tables,Ra1x Table,Ra 1,1,Num Ra Tables,Ra1x Table,Ra 2,4,Num Ra Tables,Ra1x Table,Ra 3,8,Num Ra Tables,Ra1x Table,Ra 4,-8,Num Ra Tables,Ra1x Table,Ra 5,-1,Num Ra Tables,Ra1x Table,Ra 6,2,Num Ra Tables,Ra1x Table,Ra 7,-5,Num Ra Tables,Ra1x Table,Ra 8,0,Num Ra Tables,Ra1x Table,Ra 9,1,Num Ra Tables,Ra1x Table,Ra 10,1,Num Ra Tables,Ra1x Table,Ra 11,6,Num Ra Tables,Ra1x Table,Ra 12,8,Num Ra Tables,Ra1x Table,Ra 13,21,Num Ra Tables,Ra1x Table,Ra 14,10,Num Calibration,Data,CC Gain,12.166,mOhm Calibration,Data,CC Delta,12.144,mOhm Calibration,Data,CC Offset,-1432,Counts Calibration,Data,Board Offset,11,Counts Calibration,Data,Int Temp Offset,1.9,°C Calibration,Data,Ext Temp Offset,1.0,°C Calibration,Data,Pack V Offset,-22,mV Calibration,Temp Model,Ext a Coef 1,-11130,Num Calibration,Temp Model,Ext a Coef 2,19142,Num Calibration,Temp Model,Ext a Coef 3,-19262,Num Calibration,Temp Model,Ext a Coef 4,28203,Num Calibration,Temp Model,Ext a Coef 5,892,Num Calibration,Temp Model,Ext b Coef 1,328,Num Calibration,Temp Model,Ext b Coef 2,-605,Num Calibration,Temp Model,Ext b Coef 3,-2443,Num Calibration,Temp Model,Ext b Coef 4,4696,Num Calibration,Temp Model,Ext Ideal AD at Tcal,11703,Num Calibration,Temp Model,Ext True AD at Tcal,11338,Num Calibration,Current,Deadband,5,mA Security,Codes,Sealed to Unsealed,36720414,Hex Security,Codes,Unsealed to Full,ffffffff,Hex
- Run the learning cycle with 2000mA discharge (CC load) and 2050mA charge (BQ24192).
The following log shows the state changes during discharge (to 2900mV) and subsequent full charge (to 4200mA and 256mA taper). A detailed log of the actual voltage/current logs is attached. learn log 1.txt
2017-05-18 12:29:48 Discharge controlStatus=0294, flags=013C, qmax=1000, updateStatus=0, raUpdates=1
2017-05-18 12:29:51 Discharge controlStatus=0284, flags=013D, qmax=1000, updateStatus=0, raUpdates=1 (dsg=1)
2017-05-18 16:27:46 Discharge controlStatus=0284, flags=013F, qmax=1000, updateStatus=0, raUpdates=1 (sysdown=1)
2017-05-18 17:54:21 Relax controlStatus=0284, flags=013F, qmax=1000, updateStatus=0, raUpdates=1
2017-05-18 17:55:26 Relax controlStatus=0294, flags=013E, qmax=1000, updateStatus=0, raUpdates=1 (dsg=0)
2017-05-18 17:56:26 Relax controlStatus=0A84, flags=013E, qmax=1000, updateStatus=0, raUpdates=1 (cca=1)
2017-05-18 17:56:41 Relax controlStatus=0294, flags=013E, qmax=1000, updateStatus=0, raUpdates=1 (cca=0)
2017-05-18 18:55:31 Relax controlStatus=0A84, flags=013E, qmax=1000, updateStatus=0, raUpdates=1 (cca=1)
2017-05-18 18:55:46 Relax controlStatus=0284, flags=013E, qmax=1000, updateStatus=0, raUpdates=1 (cca=0)
2017-05-18 19:54:21 Relax controlStatus=0294, flags=013E, qmax=1000, updateStatus=0, raUpdates=1 (IT ENABLED)
2017-05-18 19:54:26 Relax controlStatus=0293, flags=013E, qmax=1000, updateStatus=0, raUpdates=1 (qen=1, vok=1, rup_dis=0)
2017-05-18 20:00:51 Charge controlStatus=0291, flags=013E, qmax=1000, updateStatus=0, raUpdates=1 (vok=0)
2017-05-18 20:00:58 Charge controlStatus=0283, flags=013C, qmax=1000, updateStatus=0, raUpdates=1 (vok=1, sysdown=0)
2017-05-18 20:22:00 Charge controlStatus=0283, flags=0138, qmax=1000, updateStatus=0, raUpdates=1 (soc1=0)
2017-05-18 20:27:29 Charge controlStatus=0283, flags=0038, qmax=1000, updateStatus=0, raUpdates=1 (chg=0)
2017-05-19 03:48:20 Charge controlStatus=0283, flags=0238, qmax=1000, updateStatus=0, raUpdates=1 (fc=1)
2017-05-19 04:08:37 Relax controlStatus=0283, flags=0238, qmax=1000, updateStatus=0, raUpdates=1
2017-05-19 04:09:39 Relax controlStatus=0A83, flags=0238, qmax=1000, updateStatus=0, raUpdates=1 (cca=1)
2017-05-19 04:09:59 Relax controlStatus=0293, flags=0238, qmax=1000, updateStatus=0, raUpdates=1 (cca=0)
2017-05-19 04:46:59 Relax controlStatus=0291, flags=0238, qmax=1000, updateStatus=0, raUpdates=1 (vok=0)
2017-05-19 05:08:54 Relax controlStatus=0291, flags=0138, qmax=1000, updateStatus=0, raUpdates=1 (chg=1, fc=0)
A few observations...
- The charger (bq24192) actually stopped at a taper current of 323mA (256+27%) which is higher than the maximum in the datasheet but all our units behave that way although I don't know why. The taper current was still low enough for the gauge to register end of charge and set fc.
- Integrating the current passed during charge yields a figure of almost 98% of design capacity 11725mAh. I've read in a post that there is a 90% threshold that must be met during the learning cycle (which it is).
- The SOC reported by the gauge rises from 0 to 100% during charge in about 20min, presumably because the qmax is incorrect (default).
Following through the 'Achieving The Successful Learning Cycle' application report, I am at a loss to explain what is going wrong. Any help would be greatly appreciated.
Cheers, Ross
