Other Parts Discussed in Thread: SN74LVC2G08, SN74LVC2G125, SN74LVC1G98
Can you please suggest a way to disable the Gate Driver LM5113 in case an overcurrent/Over temp is occurring.
Pulling LI and HI Input pulses to ground would mean that i am exceeding the output source current limitation of microcontroller. If using a current limiting circuit for the same would mean i am introducing a more delay while normal operation.
Will pulling the HB Pin to Ground be enough for disabling the gate pulses for HI Switch.
Please suggest a good approach for disabling the LM5113 Gate Driver.
Arjun
