  • TI Thinks Resolved
TLV62569: TLV62569APDRL - Efficiency calculation
Part Number: TLV62569
I am currently working on "calculating efficiency for Sync-Buck Dc-Dc converter TLV62569APDRL".
The following are the design parameters:
Input voltage, Vin = 3.6 V DC
Output voltage, Vout = 3.3 V DC
Output current, Iout = 200 mA
Please provide the following details, to calculate the “Switching Loss”, I am not able to get these values in Datasheet.
(Reference: TI Application Note: SNVA237A–September 2007–Revised April 2013)
1. tswHS_rise          - High-side MOSFET rise time (the time it takes the gate voltage to rise from its threshold value to the end of the plateau interval)
2 .tswHS_fall           - High-side MOSFET fall time (the time it takes the gate voltage to fall from the beginning of the plateau interval to the threshold value)
Thanks & Regards,
Durgesh Sabnekar
  • Hi Durgesh,
    Thanks for posting we will get back to you by Monday
    _____________________________________________________________________
    You may find interesting additional information in our LPDC App Notes
  • In reply to Sabrina:
    Hi Durgesh,
    There parameters are not available for publishing, although the app notes describe a complex equation, the IC model is more complex.
    The switching losses have been modeled in Webench, I would recommend to use the Webench modelling for your calculation.
    I would suggest to simulate it for your application condition and use the IC losses "IC Pd" for calculating the efficiency in your particular application, with your BOM.
