• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » AC/DC and Isolated DC/DC Power » AC/DC and Isolated DC/DC Power Forum » slaa391 - Capacitor power supply for MSP430
Share
  • Forum
Options
  • Subscribe via RSS
This question is answered
Andre Gomes
Posted by Andre Gomes
on Feb 07 2012 10:25 AM
Prodigy190 points
Greetings,
Regarding the application report slaa391, I am implementing the capacitor supply from page 3, figure 2.
My question to you is  what is the purpose of the inductances (ferrite) and the potentiometers connected between each phase and the neutral point.
I'm quite confused because I couldn't find reference to any of these components in related application reports or in the forum.
Thanks in advance,
André Gomes
slaa391 msp430
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Glaser
    Posted by Chris Glaser
    on Feb 09 2012 09:42 AM
    Guru59305 points
    This circuit is explained in much more detail in this app note: http://www.ti.com/lit/an/slaa024/slaa024.pdf
    I will move this post to the isolated forum, where these types of supplies are more common.  The ferrite is likely for EMI/EMC reasons.
    Report Abuse
    • Reply
  • John Bottrill
    Posted by John Bottrill
    on Feb 09 2012 09:57 AM
    Mastermind25130 points
    Andre,
    The SLAA391 doesn't appear in my search of TIs documents. Can you send a copy of the document?
    John
    John Bottrill
    Report Abuse
    • Reply
  • John Bottrill
    on Feb 09 2012 10:15 AM
    Andre,
    I received a copy of SLAA391 and have taken a look at it. I am not familiar with the design. My best guess is that it is to prevent high frequency transients form entering the system.
    Sorry I really can't help here.
    John
    John Bottrill
    Report Abuse
    • Reply
  • Andre Gomes
    on Feb 09 2012 12:46 PM
    Prodigy190 points
    John,
    Thanks for replying, indeed the inductances together with the potentiometers stand as a low-pass filter to high-frequencies. But I'm new to this area and I thought it would be best to ask someone before connecting each phase voltage to the neutral point through a resistance. This is where it gets tricky, I must have the frequencies of the signal up to 3kHz, and in order to have that the potentiometers must be of 10 to 100 ohm (assuming a value of few mH in each ferrite), this would likely lead to a short-circuit between the phase voltages and the neutral voltage... the obvious solution is to increase the values of the ferrite, but I know what consequences come from that, hence my question.
    Chris,
    Thank you for replying, I've read through slaa024 but unfortunately it makes no reference to the potentiometers or ferrite.
    Andre Gomes
    Report Abuse
    • Reply
  • Andre Gomes
    on Feb 09 2012 12:48 PM
    Prodigy190 points
    *correction* ...I don't know what consequences come from that, hence my question.
    Report Abuse
    • Reply
  • John Bottrill
    on Feb 09 2012 13:08 PM
    Andre,
    Since I am unfamiliar with the design and would only be guessing I have forwarded your question to someone who might be able to answer. Unfortunately he is in Europe so I don't expect an immediate answer.
    John
    John Bottrill
    Report Abuse
    • Reply
  • Andre Gomes
    on Feb 09 2012 16:15 PM
    Prodigy190 points
    Thank you!
    Report Abuse
    • Reply
  • Steve Underwood
    Posted by Steve Underwood
    on Feb 09 2012 19:39 PM
    Verified Answer
    Verified by Andre Gomes
    Intellectual850 points
    The "potentiometers" are incorrectly drawn. They are actually surge suppressors (VDRs). The ferrite inductors in the the three phases are bead inductors. These and the larger inductor in the neutral are for EMI and RF suppression purposes. In particular they are needed to avoid destabilising the MCU during the kind of EMI attack simulated in the standard fast pulse transient tests. The one in the neutral lead could probably be a lot small.
    I hope the helps.
    Report Abuse
    • Reply
  • Andre Gomes
    on Feb 10 2012 18:48 PM
    Prodigy190 points
    I does help a lot, thank you very much.
    Do you happen to know what are the typical values for the ferrite inductors and the VDRs?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
