• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » AC/DC and Isolated DC/DC Power » AC/DC and Isolated DC/DC Power Forum » UCC28950 current sensing
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
SteveW
Posted by SteveW
on Feb 28 2012 03:33 AM
Prodigy90 points
Hi
I am looking at designing a converter based on the 28950, and hopefully migrate to a DSP, but I have a question about the current sensing.
I have been using the excel design tool (sluc222b) which is making life a lot easier, but I have a problem with a large primary current, the application will result in a peak current of about 150A (Ipp in the design tool). Obviously measuring this isn't going to be easy but I was wondering if anyone has ever used current sense resistors and an amplifier instead of of current transformer. Do you know of any issues that will or are likely to crop up if I tried (a lot of) current sense resistors and an amplifier instead of the current transformer.
I understand that it needs to be configured to produce 2V at the peak current to allow the current limiting aspect of the 28950 to work. The reason I ask is that even looking at a current transformer it will be difficult to measure the current without generating a lot of loss in the sense side circuitry, and a surface mount option is much more desirable that through-hole.
Steve
PWM Controller UCC28950
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • CWilson
    Posted by CWilson
    on Feb 28 2012 06:09 AM
    Expert1730 points
    We're using the Si8503 [SO-20], but that's below 20A.. and then a small OPA830D amplifier to match the voltages for the UCC28950.
    Report Abuse
    • Reply
  • SteveW
    Posted by SteveW
    on Mar 08 2012 04:14 AM
    Prodigy90 points
    Thanks for the reply, we already used an INA139 elsewhere so I will have a try with that.
    On the excel design tool certain parameters are locked, obviously to stop them being messed with, unfortunately as I'm doing a boost version these parameters aren't valid for out application. Is there a way of getting the password or an unlocked version of the tool?
    Steve
    Report Abuse
    • Reply
  • CWilson
    Posted by CWilson
    on Mar 08 2012 04:39 AM
    Expert1730 points
    Are you sure that your INA139 i quick enough to respond to the current and then make the UCC28950 regulate from that? As I can see, the response time is 20us for the INA139 when G=100.. Make sure your gain i small. See page 5 the 4 figures on top.
    Report Abuse
    • Reply
  • SteveW
    Posted by SteveW
    on Mar 08 2012 04:48 AM
    Prodigy90 points
    I hadn't got far enough to look at that, the gain will be between 10 and 20 so it's looking pretty marginal. Going to have another look for a current sense, anything spring to mind?
    Steve
    Report Abuse
    • Reply
  • CWilson
    Posted by CWilson
    on Mar 08 2012 05:19 AM
    Expert1730 points
    If you're not using the Si85XX, then a solution with the THS4281 could be a solution with a shunt resistor. This circuit is found the the e2e community if you search UCC28070 and current sense.
    Report Abuse
    • Reply
  • SteveW
    Posted by SteveW
    on Mar 14 2012 07:40 AM
    Prodigy90 points
    Thanks for the response.
    I have been looking at the circuit, trying to determine if noise suppression would be required in my application, if not, what the circuit would look like.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
