• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » AC/DC and Isolated DC/DC Power » AC/DC and Isolated DC/DC Power Forum » LM5025
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
LM5025
LM5025
This question is not answered
WILLIE L. MCCAIN
Posted by WILLIE L. MCCAIN
on Apr 12 2012 19:16 PM
Prodigy170 points
ON THIS PART IS THERE  ANY PROBLEMS WITH THIS PART WORKING AT 400 HZ OUTPUT
CH.A /CHB
BY SETTING THE RESISTOR FROM PIN5 TO PIN 6 THIS WILL PRODUCE PWM FOR PUSH-PULL APPLICATION ARE FULL BRIDGE BY USING EXTERNAL DRIVERS LIKE THE LM5112 /LM5110
Power Supply
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Terry Allinder
    Posted by Terry Allinder
    on Apr 13 2012 12:22 PM
    Intellectual1810 points
    Willie,
    Yes connecting a resistor from pin 5 to pin 6 will produce a PWM output for a push-pull, but  you will need to use an external driver.
    No the the LM5025 was not design to have an oscillator frequency of 400Hz, its' minimum oscillator frequency is around 100kHz.
    Terry
    Report Abuse
    • Reply
  • WILLIE L. MCCAIN
    on Apr 13 2012 13:34 PM
    Prodigy170 points
    OKAY THIS WILL BE GOOD FOR THE BOOST APPLICATION
    100KHZ IS GOOD FOR THAT
    OKAY OUTPUTS 5/6 WILL BE TIED TOGETHER WITH TWO DIODES AND INPUTED INTO A NON-INVERTING DRIVER LIKE THE LM5110 ITHINK
     TO DRIVE THE EXTERNAL MOSFETS, I NEED TO MAKE A BOOST POWER SUPPLY WITH 18VDC TO 33 VDC INPUT AND HAVE APPROX. +250 VDC OUTPUT AT 5 AMPS CONT.
    THIS PART WOULD BE OKAY FOR THAT APPLICATION
    LET ME NO
    NOW ON THE REGULAR PWM CPONTROLLER THAT I CAN USE FOR THE 400 HZ APPLICATIONS
    LET ME NO THE BEST PART NUMBER WITH ALL THE HOUSE KEEPING FEATURES
    Power Supply
    Report Abuse
    • Reply
  • Terry Allinder
    on Apr 13 2012 15:44 PM
    Willie,
    If you want a boost, you may want to look at the LM5032, it can be used as a dual interleaved boost, this would reduce the output capacitor ripple current. I've attached the applications note. 4617.lm5032appnote.pdf
    You could use the LM5025 if you want, the driver outputs are pins 8 and 9.
    In the LM5K series of controllers I am not aware of any parts that will operate down to 400Hz.  Maybe you can explain to me what you are trying to do, so I can make a recommendation.
    Terry
    Report Abuse
    • Reply
  • WILLIE L. MCCAIN
    on Apr 13 2012 16:49 PM
    Prodigy170 points
    YES I NEED TO DESIGH A STATIC INVERTER AT 400 HZ
    WITH 18VDC -33VDC MAX.
    I WILL BE DRIVING IN PUSH-PULL FOR THE LOW POWER UNITS AND FULL BRIDGE FOR THE HIGH POWER APPLICATION I NEED A CONTROLLER THAT CAN WORK DOWN IN THE 800HZ RANGE
    Power Supply
    Report Abuse
    • Reply
  • Terry Allinder
    on Apr 13 2012 18:13 PM
    Willie,
    I am going to have to check around and get back to you on this.
    Terry
    Report Abuse
    • Reply
  • Terry Allinder
    on Apr 16 2012 10:36 AM
    Willie,
    I checked around, here is an application note for a DC-AC inverter, maybe this will help.
    Terry2821.microinverterapp.pdf
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
