• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » AC/DC and Isolated DC/DC Power » AC/DC and Isolated DC/DC Power Forum » UCC28070 restarting
Share
  • Forum
Options
  • Subscribe via RSS
UCC28070 restarting
UCC28070 restarting
This question is answered
Michal Sitta1
Posted by Michal Sitta1
on Jul 11 2012 03:25 AM
Prodigy250 points
Dear All,
I am trying to build PFC with UCC28070, I have only first version of PCB and I already know that my layout isnt good enough and need to be rerouted. But even with this i should be capable to findout where is problem with my design. According to my scope measurement it seems that IC is periodicly reseting it self but for now i dont know why?
Channel 1 is SS pin
Channel 2 is VAO pin
Channel 3 is VINAC pin
Channel 4 is IMO pin
This design was created according to you xls file for correct selection of component values.
Parameters of PFC 1500 W, Uout 400 V, external synchronization at 200 kHz (generated frequency is 400 kHz)
Test conditions: Uin 85 VAC, Uout 400 V, Rload=20 kohm (with smaller resistance output voltage starts to fall down)
During normal conditions is PF over 0,9, but it is highly lowered during reset condition.
I am sorry for so much interference in this picture, but my probes are with large signal loops and some signals are deformed because of layout. (tested by probe with small signal loop)
According to
Thanks in advance for any suggestions.
PFC ucc28070 AC/DC
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Michal Sitta1
    on Jul 11 2012 06:34 AM
    Prodigy250 points
    According to datasheet, there are only 3 conditions for restart:
    1/ over heat of IC - checked by thermocamera and it seems to be ok
    2/ undervoltage on VSENSE - checked by probe with small loop and it seems to be ok
    3/ undervoltage of UCC28070 - checked by probe with small loop and it seems to be ok
    Can anybody send me or post correct form of signal SS or describe what is happening in my design?
    I have same troubles with reseting (pin SS pulled-down to gnd) during power on and it takes about 20 second to reach 400 V output level.
    Report Abuse
    • Reply
  • John Bottrill
    Posted by John Bottrill
    on Jul 11 2012 07:48 AM
    Verified Answer
    Verified by Michal Sitta1
    Mastermind25130 points
    I would relook at the Vsense input because teh botht he VAO and IMO are increasing dramatically just prior to shutdown.  This would indicate that the Vsense voltage is dropping.
    If you don't find the problem attach a schematic with component values and i will take a look at it.
    John
    John Bottrill
    Report Abuse
    • Reply
  • Michal Sitta1
    on Jul 12 2012 08:29 AM
    Verified Answer
    Prodigy250 points
    Thank you for your help, I will test it probably tomorrow.
    I have same problem during power on phase, when output voltage is lower than 400 V. It will take about 20 second to reach 400 V (without any load) because of reseting.
    Report Abuse
    • Reply
  • Michal Sitta1
    on Jul 13 2012 08:18 AM
    Verified Answer
    Prodigy250 points
    Dear John,
    Thank you for your help. I relook Vsense voltage and find out that I measure over-voltage condition about 3,4 V (460 V) for 40 us after reset. So I focused myself on grouding near voltage devider and found mistake in my design. I had connected devider to power ground instead of signal ground.
    Now I have trouble with voltage and/or current loop. Output voltage isn't stable but it is changing from 380 V to 460 V, but I hope that this I will fix on my own.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
