• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » AC/DC and Isolated DC/DC Power » AC/DC and Isolated DC/DC Power Forum » lm5050-1 problem
Share
  • Forum
Options
  • Subscribe via RSS
lm5050-1 problem
lm5050-1 problem
This question is not answered
Thomas Smith2
Posted by Thomas Smith2
on Jul 27 2012 11:30 AM
Prodigy40 points
we have a huge problem with lm5050-1 device. Everything is connected as in datasheet:
Pin1: via 100Ohm to mosfet-Drain, 100nF to gnd
Pin2: GND
Pin3: GND (always on)
Pin4: connected to mosfet source
Pin5: connected to mosfet gate
Pin6: connected to mosfet drain
We have two supply lines (+5V, +12V).
On +5V lm5050-1 drives gate voltage of mosfet to only 6.5V (this is hardly enough to be in conduction state)
On +12V lm5050-1 drives gate voltage to only 11.5V! Current flows through body diode, huge losses.
I have included a pcb picture. everything is shown except gnd connection.
c1 is 100nF, r1 is 100 ohm.
 What would you do to solve this issue?
Thanks!
lm5050-1 lm5050 mosfet problem
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Thomas Smith2
    on Jul 27 2012 12:04 PM
    Prodigy40 points
    short clarification:
    This picture shows 2 parallel mosfets (+12V supply line).
    The same problem applys on our single mosfet +5V supply line.
    Thanks!
    Report Abuse
    • Reply
  • Donald Jones
    Posted by Donald Jones
    on Jul 27 2012 17:15 PM
    Expert6805 points
    Gnd connection to LM5050-1 pins 2 and 3 are not obvious in the pcb picture. Beyond those two pins I don't see anything that looks wrong.
    I presume the gate voltages you mention are with respect to ground.
    A schematic might be helpful, and part # for the mosfet.
    Report Abuse
    • Reply
  • Thomas Smith2
    on Jul 29 2012 08:10 AM
    Prodigy40 points
    the gnd connections are created by gnd polygon plane and visible in the following picture:
    Part number of mosfet:
    digikey: IRLR8743TRPBFCT-ND
    Mosfet N-Channel 30V 160A
    http://www.irf.com/product-info/datasheets/data/irlr8743pbf.pdf
    And schematic:
    We have 15 of this chips soldered (2 Mosfet in parallel for 12V operation, 1 Mosfet for +5V bus)
    All show same behaviour. Thanks for your help, we planned to do an initial run of several hundred  boards and didn't expect problems with this chip...
    Tom
    Report Abuse
    • Reply
  • Thomas Smith2
    on Aug 01 2012 10:24 AM
    Prodigy40 points
    just to make sure:
    When I am reading "SZHB" on the device, the pin on the left bottom is pin 1, right?
    At moment there is no solution for this problem :(
    Is there anyone here using this chip?
    Report Abuse
    • Reply
  • Donald Jones
    on Aug 01 2012 11:32 AM
    Expert6805 points
    " ... the pin on the left bottom is pin 1, right? ..."
    Yes, in addition there is typically a 'hard-to-see' impression in the package epoxy along the pin 1-2-3 side
    As for why this is not working ... I don't know. All the info provided says this should work
    Report Abuse
    • Reply
  • Mike Russ
    Posted by Mike Russ
    on Aug 01 2012 22:55 PM
    Prodigy20 points
    After looking at the data sheet this device may operate in a misleading fashion if there is a low output load current or if you have chosen a FET or FETs that are too low in RDS for proper function.  The device does reduce VGS until there is a constant ~25mV between Source and Drain - this may be why you are  seeing a lower VGS than expected.   If still in doubt I would remove the mosfet / mosfets from a PCB and then using a high impedance DVM (digital volt meter) check that the gate drive pin (pin 5) of the IC is higher by somewhere between 7 & 14 volts than the in or source pin (pin4).  Without mosfets fitted, you should find ~7V higher (ie 12V relative to gnd) with 5V applied, and ~14 volts higher (ie26V relative to gnd) with 12V applied).  This should tell you whether the IC is functioning.  Then test the FET ( put the DVM on diode test, apply + lead to the FET gate & - to the source.  Now being careful not to touch the Gate check the + to Drain and - to Source is low impedance - whilst doing this touch the gate/source with your finger & voila - high impedance again - if this occurs your FET is OK, you just charged the gate up with the diode test voltage, proved it could hold gate charge for a few seconds (usually minutes) and that the fet  turned on with the small Gate charge, and then off when the charge was removed .   Do use a CRO to check each pin of the IC (relative to ground) if you are still not making progress - you could find ripple or glitches or something else unexpected.  Dont give up - everything has an answer / reason - you just need to find it !  Perhaps noise (ripple) from the circuit at the output, is falsely triggering the reverse current comparator, in which case try increasing C1 or decoupling the output with an appropriate filter (capacitor ?) Good Luck !
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
