• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » AC/DC and Isolated DC/DC Power » AC/DC and Isolated DC/DC Power Forum » Testing UCC25706 before implementing it into boost converter
Share
  • Forum
Options
  • Subscribe via RSS
This question is answered
Jesse Walker1
Posted by Jesse Walker1
on Aug 01 2012 11:55 AM
Prodigy50 points
UCC25706.pdf
Hi everybody
I have never used this kind of IC before and have never really fully designed a boost converter ethier. I thought this would be a great learning experience. With the power portion of the converter aside I had a few questions about the UCC25706 chip.
Here is a list of parameters for my circuit:
Vin(min): 36V
Vin(max): 49V
Vin(shutdown): 32V
Converter Frequency: roughly 300kHz
My circuit seems to work ok with the exception that when power is first applied to the circuit it takes almost five minutes for a PWM signal to appear on the OUT pin. There is also no output on the RC pin during this time. If I wait long enough the PWM signal, as well as the triangle wave on the RC pin, will appear. Not sure what is causing this. Any ideas?
VDD on the 25706 is 11.7V. The start up voltage in the spec sheet states: 11.2 to 12.8. So my 11.7V on VDD should be ok.
I also want to know if I can use a 0 to 5V signal on the feedback pin, I have a pot connected to it now, to simulate what the chip will see when the power portion of the boost converter is connected to it?
Attached is the schematic of my current circuit. Please feel free to view and give feedback.
Thanks in advance,
Jesse
boost boost converter
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Jesse Walker1
    on Aug 03 2012 07:58 AM
    Prodigy50 points
    It seems that the feedback pin on this chip is intended to be interfaced with an optocoupler.  So do I need to hard set the feedback voltage and only have it come on if the output voltage falls below a set level? I thought that this pin would use something similar to an error amp that would constantly adjust the feedback voltage. I thought this is what maintained the output voltage. That cant be the case if it is connect to an optocoupler....at least I don't think so. Can anyone please help shed some light on how to use the feedback pin on this IC. Thanks,
    Jesse
    Report Abuse
    • Reply
  • John Bottrill
    Posted by John Bottrill
    on Aug 03 2012 11:41 AM
    Mastermind25130 points
    Jesse,
    I'm not certain what you mean by "hard set" the feedback voltage.
    The voltage on the feedback pin will be a linearly varying voltage as a result of the feedback through the opt-coupler (look at the block diagram of the inside of the IC (figure 1 in the spec) 2/5 pf the FB voltage will be compared against the voltage on the RC pin (this is a ramp voltage) -0.7 volts and this will adjust the pulse width out of the IC to drive the converter.
    John
    John Bottrill
    Report Abuse
    • Reply
  • Jesse Walker1
    on Aug 03 2012 12:23 PM
    Prodigy50 points
    John,
    I see that now, thanks. The optocoupler through me off. I expected the output of an error amp going to the feedback pin.
    In the attached circuit (attached in the original post) there is almost a five minute delay from the time I apply power to the circuit and the time that the PWM signal appears on the OUT pin. During this time the triangle wave that is usually  present on the RC pin is also absent. Any idea what is causing this?
    Thanks for the time and effort,
    Jesse
    Report Abuse
    • Reply
  • John Bottrill
    on Aug 03 2012 12:28 PM
    Jesse,
    The max volage to startthe IC is 12.8 V what voltage are you applying?
    JB
    John Bottrill
    Report Abuse
    • Reply
  • Jesse Walker1
    on Aug 03 2012 12:46 PM
    Prodigy50 points
    John,
    I have 11.7V on the VDD pin. The start up voltage in the spec sheet states: 11.2 to 12.8. So I  would think the 11.7V on VDD should be ok?
    Jesse
    Report Abuse
    • Reply
  • John Bottrill
    on Aug 03 2012 12:58 PM
    Verified Answer
    Verified by Jesse Walker1
    Jesse,
    All parts will start somewhere between 11.2 and 12.8 volts. The one you have may start at 12 volts or not until you get to 12.8. It's a tolerance issue.
    JB
    John Bottrill
    Report Abuse
    • Reply
  • Jesse Walker1
    on Aug 03 2012 13:51 PM
    Verified Answer
    Prodigy50 points
    John,
    Made some small changes and now have  13.5V going to VDD. Works perfect.
    Thank you for taking time and helping me with such a mundane problem.
    Thanks again,
    Jesse
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
