Our customer calculated the dead time with below equation on UCC28950, and found the real test result is larger different with the calculation dataat fixed delay condition.
For example,
when we use 24K at DELAB and short ADEL to Ground to cancel adaptive delay. The real test result is 516nS, but calculation result is around 805nS with Equation3 on datasheet.
Can you help us to check if the equation is mistaken or the error is normal? Do you have the comparing curver between the real teat and simulaiton?
CH1=OUTA; CH2=OUTB
Thanks.
Oliver Ou
