Part Number: UC3860
Good afternoon,
I would like to know if there is a component similar to (UC3860) - Resonant Mode Power Supply Controller
Thank you.
Part Number: UC3860
Good afternoon,
Thank you.
Hi Anderson
You might like to look at the UCC25600 device.
This device is mainly intended for use in LLC circuits. The LLC of course has become very popular and has largely replaced the earlier resonant topologies because it offers similar performance but a much lower frequency swing.
If you give me some idea of your application I can think about it and suggest a controller.
I'd need to know - power level, input voltage range, output voltage range.
Colin
Hi, Mr. Colin.
Thanks for listening.
This information helped a lot.
But I need a 24-pin model (DIL-24) because the hardware I work with is configured for the UC3860-dil-24, and the UCC25600 is soic8.
If you have any compatible physically and pin to pin with the UC3860 thank you.
Thank you.
Hello Anderson
I couldn't find a pin fo rpin compatible alternative to the UC3860 -
You may be able to source some devices in the distribution chain - I checked a few of the major distributors but didn't find any that had inventory but that doesn't mean that there aren't some devices somewhere in the world.
Colin
