Dear Technical Support Team,
I'd like to know Ψjt of TL2845B.
It doesn't describe on datasheet.
Could you share it?
ttd
Could you share it?
ttd
Hi
Which package type do you require the data for?
I will request the thermal data once i know the package type but it can take up to two weeks before it is available
Peter
Hi Peter,
Thank you for your reply.
Package : D(R-PDSO-G8)
I'd like to use Ψjt as soon as possible.
I'm looking forward to the data of Ψjt.
ttd
Hi
The Thermal data is as follows
Result- Theta JA-High K (standard datasheet value) |
82.1 |
Result-Theta JC, top (standard datasheet value) |
38.3 |
Result-Theta JB (standard datasheet value) |
38.1 |
Result- Psi JT (standard datasheet value) |
6.6 |
Result- Psi JB (standard datasheet value) |
37.7 |
Peter
